my little lunt60 mod
highfnum
Has thanked: 57 times
Been thanked: 1204 times
Post by highfnum »
take lunt 60 and unscrew front 60mm lens assembly
then insert a 75 mm by 250 mm plano convex lens 20mm closer to etalon
highfnum
Re: my little lunt60 mod
Post by highfnum »
push down to proper place
highfnum
Post by highfnum »
place 75 ERF in front to prevent extra heat and tone down brightness
highfnum
Post by highfnum »
here is some pics of result --plz excuse pollen dust on lens - its that time of year
image of sun is slighty smaller - but brighter and can use barlow
not sure of gain in doing this - but i could so I did
highfnum
Post by highfnum »
new image size
Post by swisswalter »
Hi John
a wild mod. Seems to work
Has thanked: 20813 times
Been thanked: 10484 times
Cool stuff! :)
GUS
Has thanked: 102 times
Been thanked: 213 times
Post by GUS »
Hi John,interesting mod,also noticed the shoelace tied to the BF,which I figure is tied off to the focusing tube to stop the BF from sliding out(something so simple)Good idea.
Hi GUS
eagle eyes ;)
GUS
Post by GUS »
Hi Walter, having a Lunt scope myself I know how easily the BF can slip out of the focuser tube,but never considered any fix for it until I noticed johns solution(and so simple).
GUS
:bow2 GUS some times less is more
highfnum
Post by highfnum »
funny i show how to convert 60mm to 75mm scope for 240$
and everyone is thrilled over a 25 cent shoelace
so..
here is shoelace mod
highfnum
Post by highfnum »
and here is test :D
Hi John
thanks for the close up of the shoelace
GUS
Post by GUS »
Hi John,I was actually zooming in on the solar finder (another neat and simple solution),when I noticed the shoe lace. I usually scan around mod photos to get ideas ,and sometimes you come across something, and think to your self why didn"t I think of it, and yes Walter sometimes less is more.
On another note, how does the mod work visually,and where did you get the lens from.
GUS
highfnum
Post by highfnum »
Sun finder made from aluminum
stock
but my cool idea at back
there is a small cut and polished diamond
that glint when light hits it
highfnum
Post by highfnum »
I got lens from Edmund
GUS
Post by GUS »
HI John,LOL,but seriously how does it compare visually to the 60mm lens.
Thanks GUS.
highfnum wrote:Sun finder made from aluminum
stock
Hi John
a very interesting idea with the diamond. What size of diamond do you need?
highfnum
Post by highfnum »
1/10 carat or less
smaller in this case is better more accurate locator
round cut and polished not rough
NYC is big diamond district
you can get for 5 to ten dollars
smaller is more accurate
Big diamonds are for the women!
highfnum
Post by highfnum »
One hard thing is mounting
try not to get glue in front of diamond
will make dull and defeat purpose
Hi John
thank you very much. I'll get one and will report. Maybe you have come up with a wonderful new solarsearcher idea
highfnum
Post by highfnum »
Also notice
distance to fron those is short
smaller image more accurate
Hi John
I will remember ;)
highfnum
Post by highfnum »
Walter
diamond is 1mm to two millimeter diameter
1mm is 0.01 carats
real small
Not 1/10
Hi John
thanks a lot for the size information
highfnum
Post by highfnum »
some more test first with .60 reducer
highfnum
Post by highfnum »
with TV 2.5 barlow
shows pretty good resolution
highfnum
Post by highfnum »
orig B+W
Nice shots with the mod!
highfnum
Post by highfnum »
THX
I like this mod
completely reverseable no change to Lunt scope it self
Has thanked: 64 times
Been thanked: 4427 times
Post by MapleRidge »
Great results from the modded scope!!!
vikeljay
Post by vikeljay »
Just what does this mod do? Also, where can I pick up that convex lens? Thanks.
Jim
highfnum
Post by highfnum »
I got mine at Edmund optics
I bet If I tried I could have found one for less money
Reason for Mod
My idea was to get more resolution 60mm vs 75 mm out of same scope
second slightly faster f ratio for brighter image so when I use Barlow I got more light to work with
and do it so it was reversible without changing original spec of scope
highfnum
Post by highfnum »
i tried this mod with cheap 4 dollar lens to see if
results would equal 80 dollar lens
forget it
disk had poor detail
i got
one more
90 by 300 mm
ill get back
Hi John
good luck, we are expecting results asap ;)
highfnum
Post by highfnum »
ok I did preliminary test with 90 X 300 mm lens
I used tape and foam rubber for now i cant promise lens was optically square
but initial l test look good
here is first shot
highfnum
Post by highfnum »
lens position is critical to get sharp image
Im to close to etalon as you can see
I had to add 2 tubes to get to focus
but I will build proper lens mount and fins its proper position (I hope ;)
Hi John
yes it is all about sharpness and contrast dealing with distances. Good luck
highfnum
Post by highfnum »
so far first mod is best - 75mm by 250
I guess the 80 dollar lens was worth the money
ForrestLockhart
Post by ForrestLockhart »
Hi John,
How does the lens setup perform visually?
Forrest
highfnum
Post by highfnum »
75mm (edmund) lens works just fine visually
a litter brighter
OK
i tried with 90mm lens and changed position
also cut lens down to 83mm
I also changed position
and got what I consider second best results
75mm is still sharper
but 30 dollar lens did OK see for yourself
highfnum
Post by highfnum »
one more shot
highfnum
Post by highfnum »
above shots - no barlow
I did need (1) 4 inch extension tube due to longer focus
so here is my final config for this mod is a get a better quality lens then ill flip it
highfnum
Post by highfnum »
one more thing notice my june 28 shot was much softer before final changes
and quality of lens (DUH :D )
highfnum
Post by highfnum »
to JIM
I used edmund part # 63495 Lens PCX 75 X 250 MGF2 CTD
the 90 I gotta find papers I know its 90 X 300
all millimeters
soulvagabond
Been thanked: 4 times
Post by soulvagabond »
Seems like a good looking and cheap mod.
I will probably be purchasing a lunt ls50 shortly, so really curious, if this upgrade can also be applied. What lens size would be more appropriate, since, LS50 focal ratio is F/7, against 60's f/8.3
highfnum
Post by highfnum »
try to stay within original f num give 10 pct
soulvagabond
Thank you,
I'm a bit confused here, Lunt 60 has native f/8.3 and the convex lens you used is f/ 3.3
What's the logic behind calculating the right lens fot Lunt 50 then?
Please, bear with me, my optical knowledge is pretty vague.
highfnum
Post by highfnum »
Correct lunt has built in telecentric Barlow
Lunt native lens is very short also
If you unscrew it and test you see what I mean
