Hi All,
On September 12th we were struck by two minor CME's. One was in the early hrs (around 1:30 UT) and the second much later in the day at around 21:00 UT. These originated from a couple of flares (M4 and X1.6) released from AR2158 on September 9th.
Both of these CME's were geo-effective and detected on my magnetometers here in the North West of England. The recorded variations in local magnetic field have been converted into sound using music production software to create a solar wind effect.
Hope you enjoy the 'sounds of the solar wind'
Cheers
Stu
Sounds of the 'solar wind' - September 12th CME double hit
- Has thanked: 8559 times
- Been thanked: 8297 times
- Has thanked: 57 times
- Been thanked: 1205 times
Re: Sounds of the 'solar wind' - September 12th CME double h
very cool sounds like a gale force wind
Hi John,
It's all synthetic, of course, but the sounds (pitch/intensity) are driven by real data. The gale sounds are in a way related to the speed, density and magnetic polarity of the solar wind/CMEs as the solar protons and electrons interact with Earth's magnetic field causing a measurable change in field strength and direction here at ground level. With solar wind speeds in excess of 300km/s, peaking at around 500km/s, I thought gale sounds might be appropriate .
Cheers
Cheers
- Been thanked: 8907 times
- grimble_cornet
- Been thanked: 47 times
As a scientist and an amateur musician, that really hits the spot
Fantastic bit of data manipulation Stu
Mike Garbett
Mike Garbett
- Has thanked: 20834 times
- Been thanked: 10502 times
Incredibly impressive Stu, I like it alot. Kudos to you Sir
Hi Stuart
fantastic presentation
Many thanks for your interest and supportive comments.
They make the time and effort spent on this worthwhile.
Cheers
Cheers
