I normally use skybender with omega Ha filter in mode similar to thousand oaks prom viewer
however dynamic range is so huge that my camera just don't do well in capture (visually its great)
so
I came up with an analogy of using same filter as a "poor mans double stack" with lunt 60
I set lunt tilt once and then just used skybender to tilt omega filter only
here is pic of set up with camera
a demo with skybender
- Has thanked: 57 times
- Been thanked: 1189 times
Re: a demo with skybender
look close you can see proms come in and out of view
im using skybender to tilt omega filter only
there is some movement of sun in field do to hand touching
Hi John
yes the proms are obvious
- Has thanked: 20442 times
- Been thanked: 10248 times
good result with the omega and skybender. i use a skybender with my Cak setup, they're very good.
