Double stack; Quark + Lunt DS unit
Marcello
Been thanked: 25 times
Post by Marcello »
I just tried quickly this combination, with the Lunt DS unit 50mm after the Quark, just keeping in hand the unit and the eyepiece, so it was very quick.
Anyway I verified that I can get the focus, and the view seemed pretty nice. Now I'm going to get adapters, so that everything will be strictly fixed and I can try imaging too.
I could try also the Lunt DS before the Quark, but I wonder if the Lunt DS unit can be put after the optic without damage, I don't know exactly what filters are inside.
The optic is a 127mm, with the ERF filter.
Will update with the results!
Re: Double stack; Quark + Lunt DS unit
Post by swisswalter »
Hi Marcello
good luck with the mod. I would never use a modded system visually. so be carefull
Marcello
Post by Marcello »
Thanks Walter,
I agree with you in general, in this case I have the Quark and then the DS in combination, then I feel pretty safe, is it wrong?
Hi Marcello
you will have to make sure, that you cut away UV and IR, the etalons alone will not do that
Has thanked: 20738 times
Been thanked: 10432 times
You should only use the Lunt DS unit after the Quark, not before.
Marcello
Post by Marcello »
Thanks Walter and Mike,
I will use that only way, the Lunt DS after the Quark. I don't expect any better the other way around.
In the Quark I guess that the first grey filter before the barlow cuts UV and IR
