Replace PST 20mm etalon with a Solarmax II 60mm one?
- Moriniboy
- Oh, I get it now!
- Has thanked: 2 times
- Been thanked: 7 times
Is it possible to swap over the PST etalon in my Stage 2 scope to the 60mm one from my Solarmax II double stack unit?
Sure I have read somewhere that the PST has lenses which make the light cone parallel as it passes through the etalon and then converts it back as it exits.
With this in mind I'm assuming that using the Solarmax etalon would not work as the light would not be parallel?
Hoping for clear skies.....lol
Re: Replace PST 20mm etalon with a Solarmax II 60mm one?
Hi John
welcome to that wonderful site. Have fun in the sun. Valery from the ukraine can explain how to do it
- Has thanked: 20951 times
- Been thanked: 10588 times
Are you talking about the external 60mm etalon here?
At this moment don't think about this. You will sure failed. Better to use PST mod 2 for medium and high resolution imaging. Of course, if your PST etalon is good.Moriniboy wrote:Hi,
A 60mm scope can be used for a Full Disk (FD) imaging and for visual observing.
Valery.
- Moriniboy
- Oh, I get it now!
Thanks for your replies everyone, think I'm going to use it on a 66mm f6 scope for low power full disk and as Valery says keep the stage 2 for medium and high power work.
Will also try it on front of the stage 2 scope but reducing the aperture down to 60mm means it will then be an f16.7 scope and may not work.
- Moriniboy
- Oh, I get it now!
Decided to get an adaptor made and single stack it on the front of the Equinox 80 instead and slightly modded the inside of the etalon housing to stop reflections.
A very nice looking setup!
Hi John
that looks good, any first lights?
- Moriniboy
- Oh, I get it now!
Not the best day's viewing yesterday in the UK, but late afternoon I had a couple of cracking views between the clouds.
Loved the fact that compared to my TAL stage 2 mod I can have a full disk detailed view without a sweet spot.
As I will be mounting both side by side on a Skytee 2 I could not be happier.
Hi John
great to hear
great to hear
Excellent news!
- Moriniboy
- Oh, I get it now!
Now paired up with the TAL and as expected the TAL is brilliant for prom close up's and the Equinox shows the full disk
a setup for all situations! Nice!
Hi Nigel!
I want to make PST 2mod with my old TAL-100R (1:10). Did you shorten the tube? If yes, what is the length of the shortened tube?
Aleksey
Lunt LS100THa, Coronado SolarMax II 90 Filter + BF 15 on WO Megrez 90, PST + SW 1025 mod, Quark + SW150/750 in test mode
I did a PST mod with my Tal, I took 100mm off the tube and replaced the focuser with a moonlite.
- Moriniboy
- Oh, I get it now!
Hi Aleksey, here is a picture of the offcut next to a rule in mm. Also attached is a photo of the adaptor which replaced the original TAL focuser.
Hope they help, Nigel
Thanks Mark and Nigel!
Aleksey
Nigel can you tell me why you removed the original focuser then cut the tube by about 140mm then made a 60mm adapter then added a focuser on the end of the adapter.
So what I can see is you've cut off 140mm then added on 60mm.
Why not cut off 80mm and leave the focuser.
Maybe I'm missing something,,,,,my wife recons I'm missing something in the brain department.
Alan
- Moriniboy
- Oh, I get it now!
Hi Alan,
As the original TAL 100R focuser was 1.25" and only had 25mm of travel I was faced with 2 options
1. replace focuser with 2" version before etalon and then put a helical focuser after it.
2. replace focuser with sliding tube and then a 2" focuser after the etalon.
Picked item 2 because it was cheaper, looked better (IMO) and would lock the critical etalon distance once set.
I took off then added back because there does not seem to be a definative distance to chop off the tube (apart from approx 100mm) and I knew that any slack could be taken up by the tube.
Here are some sketches I prepared beforehand to check the logistics of what I was doing.
Ok I have a better understanding now, thank you.
Alan
