Hello All,
We discussed the ghosting issue in my Lunt LS100 when adding the DS unit in a prev thread.
http://solarchat.natca.net/viewtopic.php?f=10&t=13805
Lunt tech support recommended an upgrade to the DS unit called the HRG glass. I received the glass last week and this Sunday having wonderful deep blue skies was the ideal opportunity to test it. I ran a comparison of the LS100 without the HRG part and then with the HRG part with all other settings same. The results are negative. The HRG part does not help with the ghosting. I compared same exposures with the same camera settings. As recommended by the tech support I went through 3 rotations of the DS unit to determine if/when the ghost would be rotating to identify the responsible part. But no effect was seen.
What do the experts recommend to resolve the ghosting?
Thanks & Clear Skies,
Gert
Update on LS100 DS Ghost
Re: Update on LS100 DS Ghost
HUGE! Horrible effect!
- Has thanked: 20818 times
- Been thanked: 10487 times
Have you tried using a different camera? what happens when you rotate the camera and keep everything else static?
Hi marktonley,
Clear Skies,
Gert
Yes, multiple camera rotation has been tested to no effect. In addition the same camera used in single stack testing with no ghosting. See photos in first discussion thread.marktownley wrote:Have you tried using a different camera? what happens when you rotate the camera and keep everything else static?
Clear Skies,
Gert
I think Lunt need to be looking at getting you a replacement unit, this is not acceptable!
- Bob Yoesle
- Has thanked: 541 times
- Been thanked: 811 times
Return internal DS components for refund or credit, apply to purchase of a LS100 front etalon.What do the experts recommend to resolve the ghosting?
Have you tried to clamp something flat on one side of the DS unit when fixing it to the tube - so that the whole unit is a little bit "tilted" - maybe you don´t need much to reflect the ghost out of the FOV... Or maybe you could loosen the screws a little bit when viewing - so that you could tilt and experiment with the unit a bit - but be carefull!!!! to don´t let it fall.
The ghost looks very similar to the one I have when mounting my front DS unit at the LS60 - but this one is far outside the FOV then...
On the other side... just send it back would be a good possibility too...
Regards
Chris
Regards
Chris
"Keep it square!"
