my chromosphere/prom viewer
highfnum
Has thanked: 57 times
Been thanked: 1189 times
Post by highfnum »
60mm Unitron objective with 2X barlow, Lunt ERF
skybender filter tilter qnd omega filter
similar to HAU from thousand oaks
skybender gives good smooth tilt action
DSobserver
Been thanked: 19 times
Re: my chromosphere/prom viewer
Post by DSobserver »
wich filter from omega did you place?
Has thanked: 20442 times
Been thanked: 10248 times
Looks good! Any pictures taken with it or just visual?
highfnum
Post by highfnum »
highfnum
Post by highfnum »
geared for visual
ill try pics
Brett
Been thanked: 3 times
Post by Brett »
Which of the two filter links you mentioned did you use?
highfnum
Post by highfnum »
i have both
but cheaper one works just as well
zorgdotnl
Has thanked: 1 time
Been thanked: 5 times
Post by zorgdotnl »
Great setup!!! So you have the double stack with one filter in double pass too? not trisky with ghosts?
DSobserver
no more test or news?
highfnum
Post by highfnum »
not yet -- yes and tilting can lead to a ghost
DSobserver
no new test?
By the way how did you adapt this 25mm filter in our 1.25" eyepiece?
highfnum
Post by highfnum »
filter is in screw in filter ring
ring screws into tilting unit
DSobserver
You mean that 28mm filter holder can be screw in 31.75mm filter ring?
highfnum
Post by highfnum »
picture worth more than words
filter in and out of skybender tilter
highfnum
Post by highfnum »
out
DSobserver
PM send
