Hello sun friends,
The components for my last H-Alpha-Mod.
an older Meade ED178 f9 refractor, 2nd generation with the stable lens mount, a rare and very good scope, in DS too.
W.Lille 160mm front C-ERF, in an aluminum lightweight construction by Matthias Wirth !!
W.Lile 50/50 h-alpha-system,
with one of the best 3x military telecentric from Manfred Pieper, min. 20 meter parallel beam path. !!!
50mm original and very rare SolarScope etalon
tiltable 50mm Blockingfilter, with 52mm tiltable BG38
So the setup works with f=30
Five h-alpha enthusiasts use this system.
http://sonnenfernrohr.de/produkte-fuer- ... a-systeme/
There is so much light in this system, i often need a second 50mm BG38 , B&W-optics pro.
This project finished in august this year, and at first i make some pictures with this setup....seen here in the forum.
Visual I had bad luck this year here in cologne/germany.
Now i must wait since march/april to pick the sun from my location......
you can not have everything.
The second picture show you a part of "Solar-Cologne"
sunny Greetings
Achim
Last but not least, my biggest Mod
- Solar-Cologne
- Been thanked: 11 times
Last edited by Solar-Cologne on Fri Apr 03, 2020 5:37 am, edited 2 times in total.
- Has thanked: 20938 times
- Been thanked: 10587 times
Re: Last but not least, my biggest Mod
Looks good! May I ask a couple of questions please?
Is the blocking filter and BG38 before or after the etalon?
If it is after the etalon do you have any thermal stability issues with etalon tuning as I notice you are using a C-ERF?
- Solar-Cologne
the BG38 and the Blockingfilter are behind the etalon.
I can not answer your question, because i must wait till march/april to have a look at our sun, sorry.
In the winter i dont watch h-alpha, only with my PSt or Lunt 60, because i dont know, whats happend with the filters at cold temperatures.
sunny Greetings
Achim
sunny Greetings
Achim
If your H-a etalons are air-spaced, nothing will happens with them. Only solid spaced etalons with immersion oil inside are not suitableSolar-Cologne wrote:Hi Mark,
sunny Greetings
Achim
for using them at freeze temp.
Another points:
1. You writes that that unique military tele centric gives 20(!) meters of focal length.
Then you writes that the system works at F/30 with entrance diameter of 160mm. This corresponds to less than 5m focal length.
2. Too much light? I doubt it. NEVER enough! May be for visual, then variable polarizer can be used for brightness adjustment.
If too much light this typically indicate that your filter bandpass is too wide. A really narrow etalons typically have less light than
we want them to have.
- Solar-Cologne
Hello Valery,
I like it, that you and some others are so interested in h-alpha.
The filter mounts are smaller in cold weather, it could burst a too tightly seated filter.
sorry, ...google translate for me..
The ED178 has 1600mm, and with the 3x telecentric the scope has 4800mm, right.
Wolfgang Lille said to me, that this special telezentric has a parallel beam path from about 20 meters.
i hope, i find the right words.
sunny Greetings
Achim
sunny Greetings
Achim
Again, this is just your personal guess. I have tested several air-spaced etalons even at -15C with no problems.Solar-Cologne wrote:Hello Valery,
Achim
My information is my own _real_ experience.
And if you will search for my posts last winter you can see what kind of images one can take with air-spaced
etalons under freezing temperatures.
- Solar-Cologne
the next step is doublestack.
A PST etalon behind the 50mm Lille Blockingfilter.
sunny Greetings
Achim
sunny Greetings
Achim
