Solar Newtonian 8"
- [whrudey]
Solar Newtonian 8"
Greetings all;
Earlier this year and, inspired by Christian Viladich, I constructed an 8" Solar Newtonian shown below. An 8" f/6 mirror was purchased and de-aluminized with ferric chloride pcb etchant. The concept was to replicate a Baader Herschel wedge in that a de-aluminzed mirror reflects 4% incident light and, the Baader wedge reflects 4.6%. With the addition of a filter pack consisting of: Baader Solar Continuum filter, IR/UV cut filter and a Neutral density 3, this replication should be accomplished. The secondary was left aluminized. A truss tube design was used and I added my own version of a remote focuser and a rear projection finder. The whole system was mounted on an EQ6 GEM.
First light was disappointing to say the least even with careful laser collimation. Though exposures were similar to using the Baader wedge on my 115mm refractor, it was next to impossible to obtain sharp focus. A best example follows but, was rare compared to most others.
Multiple E-mails traveled back and forth with resulting suggestions like the following: re-collomate using a star (night skies have been cloudy); should the rear surface of the primary be ground or polished (someone claimed improved results by coating the rear ground surface with microscope immersion oil) I found no difference; cover the rear surface of the primary with flat black paper - some improvement but not impressive, etc.
By now, I began to question the primary mirror's figure and sent it to Gordon Waite for testing - he gave the mirror high marks for quality. One less variable to deal with.
Then it was suggested that some lunar images be taken and, these were passable unless I used my 3x's TeleVue Barlow. The Barlow is a standard part of my solar imaging with the DMK41 and, I'd hate to be with out it.
What I'm coming to believe is that Barlow/filter pack combination disagree with my scope - I'm otherwise running out of ideas. Have spent hours on Google with out any solution.
So, HELP ! Hopefully, someone may have other ideas - I may be stuck in my own mental "box".
Cheers,
Bill
Cheers,
Bill
Re: Solar Newtonian 8"
Bill keep trying different combos but your daytime seeing maybe the limiting factor here as your moon shot is impressive .I have a 10" SCT with Baader film and have never had conditions good enough for sharp focus whereas a 5"scope was fine.Keep going it will be worth it in the end
- [whrudey]
Thanks for the encouragement Derek. With my TS 115mm APO triplet and the Baader wedge, I've almost always been able to focus to max. under good conditions. The reason for going to the 8" Solar Newton was to take advantage of Dawe's limit with the larger optics. The TeleVue 3 x's is a very good Barlow and, I just can't figure out why it is failing now in this configuration. I'll certainly keep up the battle.
Cheers,
Bill
Cheers,
Bill
- Has thanked: 20424 times
- Been thanked: 10243 times
Do you have a completely unprocessed image straight out of autostakkert you can post - no wavelets in registax, no PSP etc.
- [whrudey]
Hi Mark;
Here are 3 from best (rare) to poor with the middle one being the most common.
Today, I'm going to substitute the Solar Continuum filter with a 58A and add a .09 ND at first. The others will include the ND3 and the IR/UV cut filters. I have a suspicion that the "apparent" silvered surface of the Continuum filter may have some interplay with the secondary - grasping at straws ?
Not sure where you're going with your request for non-Wavelet images. When focusing with my remote setup, I go in and out but, never quite get full "height" sharpness in the image.
Many thanks for your interest - will keep surging on. As noted earlier, this was never a problem with the refractor/Baader wedge/DMK41.
Cheers,
Bill
Cheers,
Bill
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
I also suspect poor seeing. Can you set up a similar size telescope (closed-tube Newt, SCT8) simultaneously and take comparison pictures?
- [whrudey]
Thanks for your input - I appreciate all the assistance I can get.
I use a TS 115mm APO triplet w/ Baader wedge quite regularly under the same seeing conditions and rarely have a problem getting clear and sharp images limited only by its small size. I repeated images this morning with the Solar Newton trying different filter combinations (swap Solar Continuum with #58 green + ND 0.9) as well as different Barlows. The Solar Continuum wins over the #58 green + ND 0.9 and, although slightly improved over previous images, the Barlows deteriorate as power increases.
Optically, I think the setup is OK given reasonable lunar images. The problems arise when filters and Barlows are added. At my latitude of 19.28, the sun is adequately high for most of the day.
This problem is quite puzzling and having adverse effects on my receding hairline. Yet, it may well turn out to be something very simple that has been overlooked.
Cheers,
Bill
Cheers,
Bill
- Has thanked: 1 time
- Been thanked: 5 times
The front black parts can increase instrumental turbulence:
-secondary holder
-front black outer part of the tube
The mount/pier also as heat waves go up.
white painting/white coton shreds ?
-secondary holder
Your images seem really noisy, I think this is also one of the issues here.
What camera are you using? Do you use gain when imaging? How many frames do you capture and how many do you stack?
- [whrudey]
Hi Mark;
I agree - the images look very "noisy". However, even before capturing a single frame, the image on the monitor is similar and not clearly sharp. This is the fundamental issue.
I use a DMK41 with very little gain and, keep the exposure low enough to get full frame rate. I've also tried my ASI120MM and ASI174mm with similar results. I usually capture 300 frames and stack 25% or less. Capture software is SharpCap 2.6 though results are no better with FireCapture 2.3. Stacking is with AutoStakkert!2 using different sized AP's without much difference - 50 seems the best. And, Wavelets are done sparingly in Registax 6 in both Default and Gaussian modes.
Sometimes, I've stacked the full AVI file in Registax 6 but, in the first window, whilst scrolling through the frames, few are sharp and, Registax chokes up.
I've since constructed a 120 mm computer box fan to cool the mirror and, will try it out once the clouds clear.
In response to zorgdotnl's post, the mount is white (SkyWatcher EQ6). I've considered making a Lycra "sock" but trials with just a towel over the truss frame made little difference. As for flat black coating of the inside of the tubing, I know of two scopes which use a solid tube and do not have my problem.
So, the saga continues. I acknowledge variations in viewing conditions and, may have become spoiled using my TS 115mm APO triplet/Baader wedge where this problem rarely exists.
I still believe that the problem is related to the Barlows and filter pack since the lunar image without a Barlow was passable. Would love to be proven wrong with a solution.
As an aside, Christian Viladrich uses a CA-k filter rather than a Solar continuum - I wonder if there is a clue here ?
Cheers,
Bill
Cheers,
Bill
- Solar-Cologne
- Been thanked: 11 times
Hello Bill,
I read very interested about your problem with your Sun-Newtonian.
Before you de-aluminized your mirror, as there was the quality at very high magnifications , possibly the star test with 400x -800x ?
When you capture with the ASI / DMK, do you use any histogram for proper exposure ?
Set by changing the parameters the histogram to the far right , then it does not rushes .
The max. gain for a DMK is 400....for the ASI i dont know.
Use "google" to look for " exposure to the right" in the internet.
You had use a DMK-41. The best focal ratio is ca. 17, like the railey- or dawes criterium.
But your Newtonian has a secondary mirror, so reduce the f something.
Sorry, when i overlooked something.
sunny Greetings
Achim
sunny Greetings
Achim
- [whrudey]
Hi Achim;
Thanks for your interest and questions.
Prior to de-aluminizing, the mirror was used successfully both for night visual observing and imaging. That was some time ago and, I can't give you details as to respective magnifications.
You may not be aware that the mirror underwent full Foucault and Rhonchi testing by Gordan Waite who concluded the mirror was above average figure.
In the past, I used to use the Histogram with both FireCapture 2.3 and SharpCap 2.6 but, now I can just estimate the grey scale based on prior years in my darkroom with film and printing in the old fashioned way of imaging.
As I've noted before, the prime issue is focusing particularly, with any one of several Barlows. I just cannot get a crisp image on the monitor. It's as if there is a film of haze somewhere in the optical path. No amount of post processing will correct for a poor initial image.
I do appreciate your input.
Cheers,
Bill
Cheers,
Bill
When I look at the unprocessed image I see a cross hatch pattern across the image. I initially thought this was a artefact of a 4 vane spider, but, I see it is a 3 vane, so this is not the cause. Almost looks like astigmatism to me, but if the barlows all work on the frac then no issues with them.
I see the primary mirror looks frosted on it's rear surface in image. Have also tried a 8" solar newt and when we did it the mirror was clear. I wonder if you have some scattering.
I would also try tilting the solar continuum too, see what happens there.
- [whrudey]
Hi Mark;
Thanks for your followup post.
Your comment on the rear surface of the primary is interesting. Christian, in this link: http://www.astrosurf.com/viladrich/astr ... /N300.html speaks against a polished surface. On the other hand, I recall and earlier post by someone else who used microscope immersion oil to "clear" the frosted rear surface and, thought this was better. I tried using Vaseline for the same effect bur, saw no imaging difference other than streaking owing to the uneven application of the jelly. Also, I tried placing a disk of flat black paper in the mirror cell behind the primary - improvement was slight but, the paper came to higher temperatures than the front of the mirror - something like 41 degrees C vs. 35 degrees C with an IR thermometer.
When you tried your 8" clear solar newt. how were your images ? Particularly when you used a Barlow.
Not quite sure how to tilt the Solar Continuum since it is screwed into a pack and perpendicular to the OA.
Please don't give up - every suggestion will be followed up on. Next, I'll try my completed mirror cooling fan and then, give some thought to repainting the inside white.
Cheers,
Bill
Cheers,
Bill
- Solar-Cologne
Hallo Bill,
I found this words in the internet:
Performance of the 3X Televue Barlow
I have been very pleased with the performance of my Televue barlow. When I first used it on Saturn, it was a little disappointing as my telescope was not collimated. The manufacturer’s statement about the telescope being perfectly collimated at the factory doesn’t mean anything if the factory is in China! All it takes is some rough seas, and you need to invest in a collimation tool.
Once I collimated the telescope, results were much better. I have not noticed any visual distortions when using the barlow, not even at the edge of the field of view. I was able to find the central star in M57 using the barlow to reach 200X. Also at 200X, M13 filled my field of view and I was able to distinguish between blue and white stars with my 8” reflector. The best view I have had of M13 was through a 13” reflector at 375X, and I could make out some red stars near the core of M13. But my telescope is smaller and was viewing M13 at lower magnification, so I cannot blame the weaker performance on my barlow. Overall, images were crisp, and I have not noticed any differences in image quality when viewing with just my Meade Series 4000 Super Plossls or when using my barlow in conjunction with these same eyepieces. I have noticed that it is difficult to achieve sharp focus higher than 200X, but that appears to be more of an issue with my standard rack and pinion focuser. I am looking into a focuser upgrade to correct this problem.
To use a Barlow with a SC or Newtonian, for high magnification, you must have a very good collimated Scope.
Today i talk with Kurt, a 76 years old semi-profi astronomer and a very good friend.
He had built more than 20 self made telescopes, Cassegrains, Dall-Kirkham-Cassegrains, Cassi with primäry and Nasmyth focus, and a solar newtonian too.
He said, your problem is the truss-tube.
You need a closed tube, GFK, GEAX....and a spcially air ventilation, because the mirror is slightly warm and a thin warm layer of air is created and ruined the image.
I hope, you understand my words....
sunny greetings
Achim
sunny greetings
Achim
- [whrudey]
Hi Achim;
Many thanks for your post - your English is much better than my German.
I would agree with the excerpt on the TeleVue 3 - it is a very good Barlow but, as such, it will magnify any imperfections presented to it.
Your friend Kurt raises interesting points regarding open vs. closed tubes. This is a controversial area as there have been posts on both sides of the argument. Christian Viladrich and Art Whipple are for the open tube and, Francois Rouviere uses a closed system. Both are able to capture excellent images.
I am giving thought to covering my truss tube with Lycra "socks" and will see how that works. Also, I've constructed a 120mm computer box fan to draw air away from the rear of the primary - yet to be tested.
As an aside, there was a 32 cm. floor fan, which we use to ventilate the observation deck, within one metre of the scope. I have wondered whether it was creating air flow near the scope which could be responsible for my problems. Today, I turned it off and, although viewing conditions were not great, I believe my captures were better than before. I'll have to pursue this when conditions are improved.
Collimation is always an issue - I've collimated and re-coollimated the scope with variable effect. May have to borrow or, purchase another laser collimator for comparison. Though it has been often suggested that a "star" collimation be done, our evening skies have not been clear recently.
I've not given up yet.
Cheers,
Bill
Cheers,
Bill
- Solar-Cologne
Hello Bill,
Ask them how thick are there mirrors and which kind of material are there mirror.
Each mirror substrate behaves differently.
sunny Greetings
Achim
sunny Greetings
Achim
- [whrudey]
Hi Achim;
Here is the link to the mirror I purchased - it is an 8" f/6 mirror made of BK-7 glass and, is one inch (25mm) thick.
http://agenaastro.com/gso-parabolic-pri ... rice-match
Here is a table of some of its qualities. It does have quite a high coefficient of expansion compared to others - could be the problem. Will try my cooling fan later.
Hope the above is helpful to you and Kurt
Cheers,
Bill
Cheers,
Bill
- [whrudey]
Hi Achim;
You and your friend Kurt may be on the right track. Until you raised the question of "what glass ?", I'd not given that aspect much thought. After looking up the properties of BK-7 and seeing how extremely high its coefficient of expansion is (83 for BK-7 and 4.8 for quartz), this may be an important issue. Given that 96% of incident light passes through the mirror, it could be adversely affected.
Meanwhile, I tried imaging using my fan on the rear of the primary. Firstly, I had it extract air by blowing out - this made a little difference. Then, I reversed the fan so that it blows on the back of the primary. Though viewing conditions were poor and a moderate breeze was present, it was my impression that the monitor images were much improved but, not perfect. IR temperature measurements of the front mirror surface showed it to be consistently about 31.8 degrees C. As I recall, previous measurements without the fan were as high as 38 degrees C.
I think the fan addition is worthwhile but, the mirror glass needs to be reconsidered as well. I note that Teleskop-Express has an 8" f/6 QUARTZ mirror at a reasonable price and, having been pleased with their service in the past, I may have to consider this as a new purchase. I'll keep trying the fan setup in better viewing conditions to see what happens. Otherwise, it may be necessary to buy a new mirror.
Many thanks for your suggestions.
Bill
Bill
- [whrudey]
Out of curiosity, what would be the consensus among members on the following two questions ?
1> Replacing my current BK-7 mirror (coefficient of expansion = 83) with a quartz mirror (coefficient of expansion = 4.8) - that's more than a 17 fold difference. This option would require an expenditure of some U$500 and, the question is, would it be worth it ?.
2> Repainting the inside of both upper/lower tubes and middle box in white. I've seen advocates for both versions. I can test this out by placing white cardboard inserts to see if any difference results.
Aside from variable/poor viewing conditions and collimation, the above may be significant variables.
Incidentally, I came across a great reference as follows:
http://www.alpo-astronomy.org/solarblog/?page_id=259
I do really appreciate everyone's help so far.
Cheers,
Bill
Cheers,
Bill
I wouldn't do any hardware changes at the moment.
I think there are cumulative factors at play here producing the end result; I don't think your seeing is supporting 8" aperture at 540nm, i'm not convinced you are getting good focus (as a result of poor seeing) and I think there is room for improvement with the stacking and post processing.
I would try an off axis mask around 3-4" aperture and see what you get, try shots without the barlow, and with. Don't use any gain on the camera, use the ND0.9 instead of the ND3 in combination with the UV/IR Cut and continuum filter. Try capturing 1500 frames per avi and stacking 100. Lets get some raw data and we can take the PP from there.
- [whrudey]
Hi Mark;
Thanks for your reply. I'll hang onto my $500 for the time being.
I agree that there could be multiple factors involved here and, seeing conditions play a major role recently. As for stacking and capture, I've used FireCapture 2.3, SharpCap 2.6, Registax 6, Avistack 2 and AutoStakkert!2 in various combinations. None of these are new to me and having made observations almost on a daily basis for the last few years, I feel comfortable with any of them. No combination so far has been able to deal with my raw AVI's which are consistently variable in focus. Adding the cooling fan has helped significantly in that as I monitor the image in SharpCap, some moments yield good images though, not enough to provide a reasonable final image. Recently, wind has been an issue as well.
I've tried stacking fewer frames without success - 10%. I always keep gain to a minimum and, have tried several variations of Barlows.
The off-axis mask seems like a good idea and I'll try it out next week. I do have a collection of ND filters and will try some lower versions still with the Solar Continuum and IR/UV cut filters. That may allow for a slight increase in fps though, the DMK41 maxes out a 15fps. Though I have an ASI174MM, I don't yet have a USB3 connection in my PC. May even try out a polarizing filter too.
Have tried capturing AVI's with more frames and stacking a very small percentage - not much difference. Will also make up some white cardboard panels to line the inside of the OTA.
So, you can see that many options have been tried thus far with more to come. There remains the question of fps - have been looking into a Basler, some of which achieve rates of 150+.
Will keep all up to date as the saga continues limited by weather.
Thanks and Cheers,
Bill
Thanks and Cheers,
Bill
- [whrudey]
Hi Mark;
Just a quick follow up on your suggestions above.
I tried an of axis 3" diameter mask without benefit. Also tried a polarizing filter with no change.
Revising the filter pack to replace the ND3 with an ND1.8 made the most significant difference thus far. Though viewing conditions have been poor (can't even get decent images with the refractor/Baader wedge), watching SharpCap's capture screen is interesting. Though there is much scintillation and movement owing to turbulence and the wind, my sense is that the images are much sharper among those flickering by given to the shorter exposure time. I can cut back on Exposure by one level and, Gain remains very low. Nonetheless, max frame rate is 15 fps with the DMK41 and, by the time a full AVI set is captured, there will have been a lot of movement. It may be worthwhile to upgrade the camera to USB3 - working on it.
You may be right about the seeing conditions not supporting this 8" scope at 540nm. Time will tell. I acknowledge the 1% rule.
All of this precludes stacking - no amount will improve a crappy capture. However, working at the capture level alone, there is still more to be done. I am reasonably confident with my stacking efforts provided the capture is good.
Cheers,
Bill
Cheers,
Bill
What exposure and gain setting were you using before and now?
- [whrudey]
In SharpCap 2.6, Exposure before was -8 and, now -9. Gain was mid-high 300's and now, low 300's.
Bill
Bill
Use zero gain, or, whatever the absolute minimum is. Have you tried firecapture? Personally I find it much better user experience than sharp cap.
- [whrudey]
Hi Mark;
Although the Gain setting I referred to in SharpCap 2.6 above is misleading at 300, the lowest it goes is 260. The range is 260 - 1023. Not sure why but, that includes the UVC Video controls as well. So, I'm not using much Gain at all - there is no zero.
As for FireCapture, I used it a lot and quite like it but now, prefer SharpCap - in the end they are all similar and, I think, it becomes a question of personal preference.
Yesterday, I removed the mirror cell and made modifications which include locking screws so that nothing changes once set. Still waiting for the clouds to go so that trials can continue.
Cheers,
Bill
Cheers,
Bill
- [whrudey]
MAJOR PROGRESS JUST MADE !!
After trying numerous different approaches and soliciting advice from others, I think the problem is now almost solved - just needs fine tuning and more practice.
Suspecting that image acquisition may be an issue, I upgraded my PC with USB 3 thus allowing full advantage from my ASI174MM in terms of frame rate. Almost immediately, under slightly improved viewing conditions, one could see improved image quality on the monitor and after capturing, stacking and wavelet manipulation, the images were substantially improved. Following are some images from this morning using only a 200 frame capture and 25% stacked. With larger sized capture files and reduced % stacked followed by more careful wavelets and other manipulations, I would hope to create some really good images.
The whole point of building a Solar Newton scope was to capture better granulation detail which had pretty well maxed out with my TS 115mm refractor. Granule detail is now far superior to anything I'd ever captured before and, should only improve with time.
With AR2462 & 2463 rounding the corner, I look forward to capturing some interesting images next week.
Many thanks to all those who offered a variety of suggestions on how to solve my problem - it was an interesting exerecise in problem solving.
Cheers,
Bill
Cheers,
Bill
- Has thanked: 173 times
- Been thanked: 615 times
Bill,
Are you saying the major problem was the imaging acquisition??
Faster frame rate the significant change??
Much better Bill.
- [whrudey]
Hi Mark and Merlin;
Yes, my conclusion is that the frame rate was the culprit on the basis of yesterday's experience - time and further captures will confirm this I hope. Otherwise, it was just a lucky break. With a "moving" target (ie: one that is flickering plus wind movement), a faster frame rate definitely made a difference. Though the DMK41 is a good imaging device, it is hampered by a maximum frame rate of 15 fps. The newer ASI174MM with USB 3 is as high as 164 fps at full resolution and, higher still with lower resolution. The improvement was instantly evident on the monitor prior to capture. This coming week will have the benefit of two new sunspots to work with and, I'm hoping for some really good images - will certainly post them as they come.
One of the things that made this exercise interesting was the many and varied alternatives suggested and tried before and after my post. With each new "idea", I rushed to try it out with high expectations only to have it fail. What I needed was an "outside of the box" flash and, perchance the USB 3 upgrade seems to have provided it.
Cheers,
Bill
Cheers,
Bill
- GreatAttractor
Bill, I'm glad that the image is now better. Looking forward to seeing some 8-inch sunspot action.
However I have some doubts regarding this:
Have you compared directly DMK41 and ASI174MM at the same conditions? I disagree that framerate itself would cause the difference in the raw images as seen on the monitor, provided the shutter times are similarly short. I'd suspect either you finally got good seeing, or the DMK41 for some other reason didn't play nice with the Newtonian (perhaps too much heat and higher sensor noise?).[whrudey] wrote:Though the DMK41 is a good imaging device, it is hampered by a maximum frame rate of 15 fps. The newer ASI174MM with USB 3 is as high as 164 fps at full resolution and, higher still with lower resolution. The improvement was instantly evident on the monitor prior to capture.
Next step is getting the post processing cranked back a bit to reduce the image noise
- [whrudey]
Many thanks to those who've shown interest in this project - I do appreciate the comments.
To GreatAttractor, though I've not yet compared the DMK41 with the ASI174MM (USB3) under identical conditions, I can tell you that the Solar Newton images I posted were under conditions where with my TS 115mm APO triplet/Baader/DMK41 at the same time, was unable to match images obtained earlier with better conditions. It was immediately evident to me on the monitor that the scanning was superior, which I assume to be the result of much shorter exposures and more of them in the same period. I was using a lower resolution so, the frame rate was even higher than the maximum of 163 at full resolution. It makes sense to me that a higher frame rate/shorter exposure would be beneficial with the scintillation and wind experienced at the time. Again, time will tell and, I will address this issue in due course - I was simply so thrilled to finally see nice granules that I didn't try other combinations at the time.
To Neo, you're right - the images I posted were quick and dirty and, were not given careful, loving attention during post processing. In time that will happen and should result in better yet images I hope. After this saga over the past several months, I'm just delighted to be now heading in the right direction after so many past failures.
To Mark, yes, post processing is an issue and be addressed in such a fashion as to keep noise to a minimum. That would result in greater detail in the granule bodies and, hopefully approach image quality of Christian Viladrich with his 10" Solar Newton and Ca-K line filter vs, my Solar Continuum. Note also, as I understand it, that Christian uses a Basler 1920 device with a frame rate of 155 fps.
Cheers,
Bill
Cheers,
Bill
- michael.h.f.wilkinson
Interesting reading this saga. Those last images are very nice indeed. The DMK41s ICX205 chip has a QE of 44% vs 78% for the IMX174 of the ASI174MM. That allows exposure times half as long for the same photon count (roughly) that should certainly contribute to better results
Good point Michael!
But doubling the number of frames stacked should give similar results....
IMHO its the faster frame rates giving opportunities to grasp those fleeting moments of good seeing...
Absolutely, but the combination of faster frame rate plus better QE is the killer combination. The ASI174MM allows you to select short exposures without reducing quality due to low photon count, and that ensures your exposure time does not become a bottleneck in selecting the frame rate. You can only hit the 164 FPS max rate if your exposure time is 6ms or shorter.Merlin66 wrote:Good point Michael!
- [whrudey]
Again, many thanks to all who offered their thoughts on my Solar Newton issues. I think that we are on the right track now with the ASI174MM given its good fps.
Today's viewing conditions were poor with a persistent haze. Nonetheless, I persisted and captured a few quick and dirty images which are light years ahead of what I'd obtained previously with the slower DMK41 - I am convinced now that this is the way to go.
Modest and, somewhat noisy samples of today's efforts follow and will appear better in the enlarged window with a dark background:
My focus at present (please pardon the pun), is to define the granule edges and retain some detail within. Despite today's poor conditions, I believe that progress is being made. Fair as today's images are, they are still better than anything I could get with my TS 115mm APO triple under ideal conditions.
With today's setup, Exposure in SharpCap was less than 2ms and resolution was set at 1280 x 1024 which, should allow maximum frame rate. On average, acquiring 300 frames took about 8 seconds which equates to about 38 fps ?? Not sure why.
I look forward to some good viewing conditions to challenge the setup.
Cheers,
Bill
Cheers,
Bill
Michael,
If you compare the QE curves for the DMK51 and the ASI 174 (assuming a max of 65% absolute for the DMK) then at H alpha the ASI 174 is 50% and the DMK51 40%
So I think it's the frame rate which improves the outcome, not the QE.
- [whrudey]
Notwithstanding QE parameters, frame rate, exposure, gain, coefficient of expansion, etc., I think my Solar Newton is good to go. Today, with better than average conditions, I capture a few images which I'll post on Solar Chat for all to see. Now, it's just a matter of improving my skills in using the scope and, the major trials and tribulations are over for the moment.
Many thanks to all those who participated in this exercise.
Cheers,
Bill
Cheers,
Bill
Any chance of a completely unprocessed version of one of the shots with the 174?
- [whrudey]
Hi Mark;
Can do but, it will have to be tomorrow morning - the files are on the Observatory computer. Are you still concerned about noise ? Remember, these images were processed in a rapid manner. I assume that you want the tiff file that comes out of AutoStakkert!2 - the AVI file is 350meg plus.
Cheers,
Bill
Cheers,
Bill
Yeah, the tiff straight out of avistack would be great thanks
- [whrudey]
Hi Mark;
Tried sending the tiff files (they're quite large) via the SolarChat Website and it choked. E-mail me at [email protected] and, I'll send them on to you directly.
Cheers,
Bill
Cheers,
Bill
Hi Bill,
Here's my take on the files:
A couple of observations; I cropped the image down before processing as the edges of it were very unsharp as you're not using the crop function in the stacking software. There's a gradient and banding across the image, not sure why but you should be able to get rid of it easily with a flat. Some focus shift too across the image diagonally - is the camera not orthogonal to the axis maybe?
- [whrudey]
Hi Mark;
Many thanks for taking the time to rework my images. I do like the improvement in grey-scale and reduced noise. You definitely teased out more fine detail in the granules.
I took the liberty of reworking your reworked version and came up with the following in both monochrome and colour. I personally prefer a little more contrast and brighter image. In the end, it all comes down to personal preference. I will work now to more closely approximate your version.
Again, many thanks.
Bill
Again, many thanks.
Bill
