Quark mod into combo
DSobserver
Been thanked: 19 times
Post by DSobserver »
hello
Did anyone already looks how to mod a quark into combo?
Andover 656.3 Å 1 nm would most probably be needed, but how to remove telecentric?
Has thanked: 20442 times
Been thanked: 10247 times
Re: Quark mod into combo
The telecentric just unscrews off the back...
highfnum
Has thanked: 57 times
Been thanked: 1189 times
Post by highfnum »
are you talking about that little ring that holds that reflective lens
or the whole black unit
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Regular Quark will work like a Combo (or even better) if to use it with 0,5x reducer.
Yeah, the whole black lens assembly just unscrews out of the quark body.
highfnum
Post by highfnum »
"Regular Quark will work like a Combo (or even better) if to use it with 0,5x reducer."
Yes Valery I have tried this and it works well
but what would screwing off the lens assembly do for you? (its a different approach)
highfnum
Post by highfnum »
Mark - still not precise enough
is the whole black part attached to the upper red part removed or
the inner 1.25 inch black stem?
Post by Valery »
highfnum wrote:Mark - still not precise enough
No! All what is before the red cylinder is removed. Only red cylinder and 1.25" visual back remain in use.
highfnum
Post by highfnum »
thx Valery
Mark -- request was not to be a negative - its just me being very careful not to destroy item
but what would be advantage of doing this?
I know John, no worries ;)
DSobserver
once more do we remove the black lens
or remove the black lens + add a 0.5 reducer
or add a 0.5 reducer in front of quark
If we talk about the 3rd option, I tried : picture of the sun is nice but full of dust and picture of kind of broken piece of glass. I mean there is superpositoin of a focus sun + focus dust fromthe quark...
