SHG 1st light of 2016: AR12529 in H alpha
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Greetings Everyone.
Back in the solar imaging game as of 13Apr. No blizzards or ice storms, just clear sky with sunshine that felt almost warm.
In addition to imaging with H alpha and Ca K scopes (http://solarchat.natca.net/viewtopic.php?f=4&t=19365), I brought the spectroheliograph out for some fun.
Since the Big Spot has made for some amazing images on this forum, I thought I'd present an animation of the spot as a spectral sweep (blue to red) through the H alpha line.
Enjoy!
More images to follow.
Peter.
Edit: Oh well, the animation looped once and never again! It works if you download and run in Windows Media Player.
Enjoy!
Peter.
- p_zetner
Re: SHG 1st light of 2016: AR12529 in H alpha
Thanks, Derek.
Here's a panel of 20/22 images of the animation. (Blue to red is upper left to lower right and I have yet to calibrate the step size.)
Peter.
Peter.
- Has thanked: 20767 times
- Been thanked: 10453 times
This is excellent Peter! I do like the sweep!
- Has thanked: 17970 times
- Been thanked: 8900 times
- Has thanked: 8543 times
- Been thanked: 8268 times
Excellent work, Peter.
- p_zetner
Many thanks Stu, Alexandra, Mark and Derek!
I'm adding a similar spectral series for the proms on the SW limb. Won't post an animation as I need to use a different computer (with Photoshop) to save the gif properly in continuous looping mode. I think that's the problem, anyway.
An interesting observation about this spectral series is that it's "lopsided". The proms are much more prevalent on the blue side of H alpha line centre, indicating that the prom plasma we are seeing has a predominant line of sight velocity approaching us. The filament has roughly the same visibility on both sides of line centre indicating that it's quiescent.
Peter.
Peter.
- DSobserver
- Been thanked: 19 times
- Has thanked: 57 times
- Been thanked: 1202 times
- p_zetner
Vincent;
It's my usual instrument but I've added a x2 photographic tele-extender (Komura Telemore) in combination with a 300mmfl telephoto for the camera lens to give more magnification in the image. The configuration here is then: 600mmfl camera lens, 500mmfl collimator lens and 1000mmfl telescope objective (Astro Rubinar catadioptric). This gives a system focal length of 1200mmfl but, with a 25micron slit, it also projects a slit image of 30 microns width (7px) on the camera sensor. I should really go to a smaller slit width for this configuration and plan to use 10 microns next time.
Ultimately, I would like to go to a longer focal length telescope ... the ideal way to magnify the image scale. I've tried the x2 tele-extender on the Astro-Rubinar for 2000mmf but the image was definitely too soft.
It looks like your new SHG will allow some "mix and match" of various camera lenses. I think this will give you some great flexibility to achieve a desired result.
Peter.
Peter.
- DSobserver
well, first trial failed....
I think that it come from using a zoom lens as a collimation : I could achieve to get a proper focus.
Middle of the sun was ok, edge a disaster...
Are you placing an ERF in front of you catadioptric?
- Has thanked: 174 times
- Been thanked: 619 times
Peter,
Glad to see the SHG active again.
Keep up the good work!
- p_zetner
Vincent;
I agree that you might have trouble with a zoom lens. They are generally of lower optical quality than fixed focal length lenses. You can probably put together a good selection of fixed focal length lenses relatively cheaply by watching eBay.
Yes, I do use a uv-ir cut filter (Schneider True Cut) in front of the objective. Here's a photo:
http://www.pbase.com/p_zetner/image/151819182
Peter.
Peter.
- DSobserver
I'll most probably use this mak (http://www.astroshop.de/fr/telescope-ma ... 80/p,46443)
Step by step, I'll build same SHG as you
