Autostakkert 3
- Has thanked: 20783 times
- Been thanked: 10464 times
Autostakkert 3
The new beta version came out for this earlier this month. It's nice, I like it, some nice feature updates. I did a quick blurb on my website, with links to download.
https://brierleyhillsolar.blogspot.co.u ... eased.html
- Has thanked: 17970 times
- Been thanked: 8905 times
Re: Autostakkert 3
Mmmm it works but impossible to close down. I have to use Ctrl+Alt+del
Can't even delete the software, it won't let me. On there for good now unfortunately
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Re: Autostakkert 3
Hmm, works without problems for me (seems faster that previous version)
Have you tried to "End" it with Task Manager instead of using Ctrl-Alt-Delete.
If you rebooted, you should be able to delete the folder where you unzipped the software. So what error message do you get when trying to delete?
Rgrds,
Rgrds,
Re: Autostakkert 3
Problem solved by the very kind Emil
I have set it to permanently run as administrator and it now closes fine
- Has thanked: 8544 times
- Been thanked: 8280 times
Re: Autostakkert 3
Thanks for pointing this out, Mark.
I'm not changing a thing on my laptop until after the eclipse......
- PDB
Re: Autostakkert 3
Stu,
then you will need to disable network access to prevent Microsoft messing up your PC with their updates. Wouldn't be suprised if they send out updates in August.
Re: Autostakkert 3
I just need some sunny skies to test it a bit more maybe today...
- PDB
Re: Autostakkert 3
Has someone tried to process multiple files? Don't get it working with AS!3. I normally use that for stacking an animation series with the same processing settings. It works in AS!2, but not output in AS!3. Maybe I have some setting that conflicts with stacking multiple files.
Re: Autostakkert 3
I've had no probs stacking multiple files. What issues are you getting?
- PDB
Re: Autostakkert 3
I do analyze, set the % of frames I like, set the alignment points and then press stack. Seems to analyze all the files again, but then stops. No files stacked. I have no problems doing this in AS!2. I have set double stack referenece, maybe that is the problem. (Will give that i try, but just removed my last session ...)
Rgrds,
Rgrds,
Re: Autostakkert 3
How many frames you recording in the avi?
- PDB
Re: Autostakkert 3
Not that much. It were around 35 10 second SER files of proms. Taken with the ASI120MM-S so these were not that big. Just tested again. Copied a 1000 frame SER file 10 times. Tried different changes in the settings (double stack, buffering, laplace) nothing helped. You see Step 1 & 2 for each image, but the other steps (allig stack ...) are not done, so nothing saved. Did exactly the same with AS2 (also the 64bit version) no problem. Think I will send an e-mail to Emiel.
Rgrds,
Rgrds,
Re: Autostakkert 3
Kool and the gang...
Re: Autostakkert 3
Post eclipse..... now downloaded and appears to be running fine
Thanks for the heads-up, Mark.
Re: Autostakkert 3
I would urge you if haven't done so already to download the latest version of 'v3' as there have been a few bug fixes and certainly for me on my old coal powered laptop things have sped up quite a bit.
http://www.astrokraai.nl/software/latest.php
