Lunt LS50+Visionking 80mm/F7.5 MOD And Questions...
soulvagabond
Been thanked: 4 times
Post by soulvagabond »
Got this Chineese 80mm refractor from Aliexpress, which apparently has good optics, but the rest is so so..
Almost a perfect candidate , for the Lunt 50 ethalon, so I did that.
The result is, both positive and negative, let me explain:
Pros:
Obviously, more details visible
Higher contrast, more 3d perception, compared to stock Lunt LS50
Cons:
Little more reflections
Keyhole effect, and lower magnifications, much harder to position the eye now, for comfortable viewing.
With the full disk in view, the prominences at the sides are less visible, than with the stock Lunt.
So, my questions are rather concerning the last 2 cons.
Guess, the reduced eye relief is due to the focal distance of the eyepieces, or, due to the BF600 filter, being at the max limit, of the 600mm focal distance of the Visionking refractor.
Which 2 of the above is more important?
Which eyepieces could give less keyhole effect, at lower zoom?
What could affect the sides of the sun not being so much on-band as vs the stock Lunt? If the sweetspot is reduced, why it doesn't seem to affect the upper and lower borders of the sun?
Thanks!
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Re: Lunt LS50+Visionking 80mm/F7.5 MOD And Questions...
Post by GreatAttractor »
Mods like this are a trade-off: better resolution for a smaller sweet-spot relative to Sun disk size (etalon incidence angles are magnified due to longer donor's focal length; you can find detailed discussion elsewhere). The non-symmetric shape of sweet-spot could be caused by some misalignment in optical train.
As for the keyhole effect, I'm afraid nothing can be done. Using a larger blocking filter won't help (it won't improve the smaller sweet-spot). Simply, use a sufficiently short eyepiece that its whole FOV is on-band. For instance, I use a 9 mm Antares Ortho with my 660 mm f.l. donor (73x).
My software:
My images
Has thanked: 20738 times
Been thanked: 10434 times
Missed this one - looks a nice mod!
Has thanked: 174 times
Been thanked: 618 times
Questions:
How did you calculate the "majic" spacing for the Lunt etalon???
soulvagabond
Set my lunt onto the mount, focused onto the Sun with 20mm eyepiece.
Unscrewed the ethalon with the diagonal and eyepiece from the scope.
Put the refractor, with the focuser removed, onto the mount instead.
Held the ethalon in the hands and tried to get the Sun in focus.
Thought I nailed it pretty accurate.
But, the adapter in the photos above, was off by 6mm. But, having it done, allowed me to do precise measurement, since, I didn't have to sweat anymore, trying to get the image in focus and aligned.
I have already ordered N.2 adapter, which is 6mm longer. Should be here Tomorrow.
Perhaps, an easier alternative, would be a 2-piece adapter, with draw tube design and the grub screws. Once you have the distance figured, you can cut off the excess.
Bear in mind, I'm not really sure, if this method really figures out the magical distance, but that's what my intuition lead me to.
Regards!
