Spectroheliograms 19Jun2017
p_zetner
Post by p_zetner » Wed Jun 21, 2017 2:15 am
Greetings Everyone.
Back in action with my spectroheliograph.
Here are two "test shots" with my reconfigured SHG using the Celestron NexStar 4SE as telescope. Two big advantages of this scope: a motorized focuser and less glass (than my previous Astro-Rubinar lens) to give better UV transmission.
A picture of the instrument:
SHG Jun2017.png (780.95 KiB) Viewed 1814 times
Pretty happy with the new arrangement so far. Focusing the Astro-Rubinar telephoto was a pain.
I was able to take advantage of cooperative weather for an extended, multi-wavelength imaging session today (20 Jun).
Hope to process and post the new images soon.
Peter.
Re: Spectroheliograms 19Jun2017
Post by Merlin66 » Wed Jun 21, 2017 7:45 am
Wooh.......
That's a very difficult balancing job!!!
Great results, look forward to seeing more.
(No ERF?)
Post by marktownley » Wed Jun 21, 2017 5:00 pm
I always enjoy seeing your work Peter! Great stuff!
p_zetner
Post by p_zetner » Wed Jun 21, 2017 8:19 pm
Thanks Mark and Ken.
Ken, here's another view of the SHG with more of the construction details visible. The entire instrument weighs about 12kg. It's not terribly more unwieldy than the previous version but I can notice flexure when viewing afternoon Sun as opposed to morning Sun. I'm trying to think of an improved mounting arrangement for the Celestron. At the moment, you can see the aluminum bar and rod used to support its weight. You can also see the counterweight on sliding bar which I use to balance (in dec).
I don't use an ERF on the Celestron. From what I can tell, apart from the corrector plate, there are only reflective optics. The Astro-Rubinar had cemented achromats near the focus.
Peter.
highfnum
Post by highfnum » Fri Jun 23, 2017 12:35 pm
wow looks complicated but works well
nice to see others doing this
Phil Rousselle
Post by Phil Rousselle » Sat Jun 24, 2017 10:20 pm
Hi Peter, your SHG is very long but works fine. K3 image has a very good bandwidth and contrast
Phil
Post by Carbon60 » Sun Jul 02, 2017 9:46 am
Very nice SHG images, Peter. Always good to see your work.
Maybe mount everything rigidly in a lightweight wooden box.... It would take away some of the beauty of this arrangement, but might make for a more stable instrument. It looks impressive, but precarious :)
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by Merlin66 » Sun Jul 02, 2017 2:57 pm
Stu,
That's what I did with the 100mm Littrow SHG, see:
viewtopic.php?f=8&t=20682
p_zetner
Post by p_zetner » Tue Jul 04, 2017 11:22 pm
Thank you all for your comments.
Phil: You should know that it was your work that motivated me to pursue "spectroheliography" in the first place! Your spectroheliograms are inspirational and your website very informative. I encourage all aspiring spectroheliographers to read through it. Thanks for the visit.
Stu: Your comments are always welcome. The suggestion of the wooden support box is good (see Phil Rousselle's original design!) but, aside from experimenting with some minor tweaks, I'm reasonably happy with my configuration at the moment. I'm planning a much larger instrument which will necessarily be housed in a box of some sort and fed sunlight through a coelostat ... a long term project!
Peter.
Post by Montana » Wed Jul 05, 2017 11:21 am
Wow, the images are lovely and a great set up too :bow :hamster:
