First dedicated solar rig on order...152THa/DS2 with B3400
Any recommendations on EP for viewing sessions? Looking at Ethos series (perhaps the 21mm if it can pull in whole solar disc views)..anybody onboard with experience using the 152 visually - what EP's have you found worked best for you (and in particularly offer good views of the entire disc).
Thanks -
Scott
Optimum Eyepiece Recommendation for Lunt 152THa/DSII
- The Sun?
- Has thanked: 20825 times
- Been thanked: 10498 times
Re: Optimum Eyepiece Recommendation for Lunt 152THa/DSII
You'll find much better views with simpler eyepeices. I use TV plossls in Ha.
- The Sun?
What size/FOV are appropriate based on the setup I have ordered (particularly if I want to suck in a view of the entire disc?)
