Omega CaK stack
Has thanked: 173 times
Been thanked: 615 times
Omega CaK stack
This stack appears to work well and gives a pretty clean and clear image.......BUT
I'm struggling to find an exposure/ gain/ gamma setting either in FireCap or SharpCap which gives acceptable frame rates (with the ASI 174MM)
Definitely better results with lower gain settings.
Can you share your exposure setting for the CaK filter you use?????
Any input appreciated.
Has thanked: 20442 times
Been thanked: 10248 times
Re: Omega CaK stack
I always run neutral gain, with the gain ramped up (power the camera by noise free battery) and the exposure as short as possible, maybe 1-2ms @ f10.
Re: Omega CaK stack
Mark,
Thanks.
What would you call "neutral gain settings"??
I realise there are differences between FireCap and SharpCap.
Has thanked: 17672 times
Been thanked: 8793 times
Re: Omega CaK stack
I think neutral 'gamma' was meant
Re: Omega CaK stack
It was! neutral gamma - it's me typing just after I woke up this morning :D
Has thanked: 156 times
Been thanked: 893 times
Re: Omega CaK stack
Post by Valery »
Merlin66 wrote: Tue Oct 10, 2017 12:05 am This stack appears to work well and gives a pretty clean and clear image
Hi Ken,
Can you, please, describe this stack as detailed as possible?
Re: Omega CaK stack
Valery,
It's a stack of three Omega filters - <390nm UV cut, 80nm 394nm cwl, and a 2A 393.7nm cwl. All adapted to 1.125" filter size.
