FDs & G-Band images (New G-Band Animation added)
yltansg
Post by yltansg » Sat Dec 16, 2017 7:36 am
Hi everyone,
Greetings from Singapore. It has been raining and cloudy for quite a while. I am glad to have 30 minutes this morning with thin layer of clouds over the Sun to get this 3 full disks. Generally a blank disk on WL and some filaments and prominences on HA and interesting areas of magnetic field concentration in the CAK image.
Alfred
Re: Full disks in 3 wavelengths and scopes used
Post by ffellah » Sat Dec 16, 2017 2:49 pm
A beautiful set, Alfred. I am glad you had some sun after a long time.
Post by eroel » Sat Dec 16, 2017 2:57 pm
Alfred:
Beautiful 3 flavor session.
Post by MapleRidge » Sat Dec 16, 2017 11:11 pm
Those are very sharp Alfred...well done :bow
Post by Carbon60 » Sun Dec 17, 2017 7:11 am
A very fine tryptic, Alfred.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by marktownley » Sun Dec 17, 2017 8:40 am
Three very nice disks Alfred!
yltansg
Post by yltansg » Sun Dec 17, 2017 1:39 pm
Thanks Mark, Stu, Brian, Eric and Franco. Seeing condition continue to be poor today. I took 2 more scopes out of cold storage. These were the images from today's session.
For H-Alpha imaging, a150mm refractor with ARIES D-ERF and Lunt 50.
This was the best of 3 H-Alpha images taken this morning (17 Dec 17)
For G-Band imaging, I used an ARIES C8 ERF with a 430nm filter
It was a struggle to get a decent G-Band image this morning.
This was taken on 1 Nov 17 with the same setup when the seeing was better.
Re: FDs, G-Band images and Scopes (New images added)
Post by marktownley » Sun Dec 17, 2017 7:44 pm
Good additions! Seeing makes all the difference!
Derek Klepp
Post by Derek Klepp » Mon Dec 18, 2017 6:42 am
Thanks Alfred and good to see the comparison in seeing conditions.
Post by Montana » Mon Dec 18, 2017 12:35 pm
A lovely traffic light! and the close ups are fab but the 1st Nov is the business :bow :hamster:
Post by ffellah » Mon Dec 18, 2017 12:46 pm
That granulation is amazing, Alfred. Well done !
yltansg
Re: FDs & G-Band images (New G-Band animation added)
Post by yltansg » Mon Dec 18, 2017 2:08 pm
Thanks Mark, Derek, Alexandra and Franco for your kind comments. Here is a time-lapse gif made from 12 stills taken on 6 Oct 17 from 7:58am to 8:06 am local time.
Enjoy it.
Alfred
yltansg
Re: FDs & G-Band images (New G-Band Animation added)
Post by yltansg » Wed Dec 20, 2017 7:29 am
pedro wrote:
Tue Dec 19, 2017 2:45 pm
Great HR (granulation) images there Alfred, well done
Thanks Pedro. I am able to get reasonable G-Band images with the Edmund Optics 25mm 430/10nm filter when the seeing is average and better. However I have not been able to get a decent image with the Baader Calcium K-Line Filter. I have been trying for some months now :( Most of the time I used the 430/10nm first and the seeing became poor by the timing I changed over to the K-line filter. Will share findings.
Alfred
Post by christian viladrich » Mon Dec 25, 2017 4:15 pm
The G-band image taken on Nov 1st is pretty good. Well done !
There is no wonder that you get unsatisfactory K line images with the C8. The spherical aberration is so large in near UV that the instrument is no longer diffraction limited.
In the whole, and for diameters larger than around 150 mm, a G-band filter gives images more satisfactory images than a K-line filter:
- the contrast is about the same,
- the sensitivity to turbulence is lower,
- most optics are much better at 430 nm than at 396 nm.
BTW, what is you exposure time with your 430nm FWHM 10 nm filter and the C8 ?
Best regards
Christian
http://www.astroplanetes.com/
yltansg
Post by yltansg » Thu Dec 28, 2017 2:24 pm
Best regards
Christian
Hi Christian,
Thanks for the valuable information. I am still hoping to catch a nice K-Line image when there is very good seeing :)
The following are the setting for the 1 Nov G-Band image:
FPS (avg.)=151 Shutter=0.082ms Gain=92 (23%)
Histogramm(min)=84 Histogramm(max)=148 Histogramm=58%
Alfred
Users browsing this forum: stef41 and 3 guests
