1.6 Solar Animation
- Has thanked: 1640 times
- Been thanked: 878 times
1.6 Solar Animation
1 hour animation. Seeing was not great but better than it has been. I need to get get better daytime alignment to fix field rotation.
Equipment
LS 80DS
Hinode guider
AVX
powermate 2.5
ZWO 174
Firecapture
AS3!
IMPPG
May take awhile to load (50MB files).
Here is a link to astrobin
http://astrob.in/full/328479/B/
Equipment
LS 80DS
Hinode guider
AVX
powermate 2.5
ZWO 174
Firecapture
AS3!
IMPPG
- 1.6SSM.jpg (657.66 KiB) Viewed 1905 times
- Solar Ha_111131_lapl4_ap2002_out_aligned_pipp.gif (41.92 MiB) Viewed 1905 times
Re: 1.6 Solar Animation
I tried to use a powermate 4x
I need more aperture.
[The extension tif has been deactivated and can no longer be displayed.]
- rsfoto
- Has thanked: 9823 times
- Been thanked: 5828 times
Great animation. What time interval did you use ?
- Has thanked: 20962 times
- Been thanked: 10593 times
Good animation! If the sky stays clear for long enough i'm looking forward to doing some animations myself later in the year.
- Has thanked: 65 times
- Been thanked: 4462 times
Great animation, and the frames are very even which shows in the video progression
- rsfoto
Thank You torsinadoc.torsinadoc wrote: ↑Sun Jan 07, 2018 4:11 pm 300 frames every 60 seconds for 1 hour. Stacked 30 frames from each run
- Has thanked: 18105 times
- Been thanked: 8942 times
- Been thanked: 5016 times
