2018/02/13 - AR2699
PDB
Has thanked: 2 times
Been thanked: 149 times
2018/02/13 - AR2699
Post by PDB »
Another one of AR2699. This was taken with the 80mm f/6 - Quark - Focal Reducer and ASI-120MM-S.
Did not use a tilt adapter, to see how bad NR's were going to be. They were there and after the flat still shining thru a bit. That was remover in software with Fast Fourier Transformation method.
Not as sharp as I would like, but this AR is to nice. It seems sharper on the left side, than on top right, and that puzzles me a bit. Looks as if the sensor or focal reducer are not lined up. Or is this just stacking with some better areas in some places of the image? Any ideas?
Rgrds,
Has thanked: 20757 times
Been thanked: 10444 times
Re: 2018/02/13 - AR2699
Good shot! Not too sure about the top right, wait till better conditions before diagnostics.
Has thanked: 17925 times
Been thanked: 8894 times
That is still a great pic, I can't see the NRs
:bow :hamster:
PDB
Post by PDB »
Thanks.
Alexandra: they are not visible anymore. Removed with sofware tricks.
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
A good result, Paul.
PDB
Post by PDB »
Thanks Franco.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Great capture Paul...great to see so many getting a chance to image it.
PDB
Post by PDB »
Thanks Brian.
Today looks promising again (amazing we had more Sun showing this week than in the last 2 months), before it dissapears over the edge.
