AR12681 C11 + ARIES full size DERF and 0,2A etalon.
Hi all,
Here is the image of the AR12681 taken early morning Sept 27 2017
with a telescope C11 equipped with the ARIES full size DERF and 0,2A etalon.
Seeing was average.
Thanks for looking.
Seeing was average.
Thanks for looking.
- Sept-27-2017-UT09h-01m--ARIES-DERF-C11-280mm-0,2A-etalon.jpg (490.82 KiB) Viewed 1842 times
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: AR12681 C11 + ARIES full size DERF and 0,2A etalon.
That's a cracking image Valery!
- Has thanked: 17970 times
- Been thanked: 8904 times
Absolutely stunning! smooth as silk
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Very impressive in scale and detail Valery.
Christopher
- Has thanked: 8543 times
- Been thanked: 8278 times
Lots of stunning detail here, Valery.
- Been thanked: 4419 times
That is an excellent image Valero...great capture and processing.
- Has thanked: 9307 times
- Been thanked: 6144 times
Excellent image and processing, Valery.
- rsfoto
- Has thanked: 9710 times
- Been thanked: 5769 times
Great image. Just one question. Why do I see that image so dark ?
I work on a calibrated Adobe RGB monitor. Every 2 weeks I recalibrate my monitor as I do print for customers on 24" wide and 17" wide printers.
Rainer,
I calibrate my monitor so, that I see with a confidence the darkest and the brightest tones of a b/w scale.
I guess Alexandra do use similar to my computer ( 17" Dell Inspiron with E-IPS screen). Let ask her is my image too dim when the
monitor shows the darkest and the brightest tines as different to second darkest and second brightest ones.
I would say your image looks fine to me, black is black and the white areas are not over exposed, with a range of grey in between. My Dell Laptop is all on default settings (never done anything). I guess when I do print out some of my images are very very slightly darker on the print, so my screen is perhaps a little on the bright side. I know Valery is more on the contrast style so some can be a bit dark but then this is art
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Wooow! Just beautiful. .
Marios
Marios
Marios S.Ioannou
Sketcher/Visual Observer
- The Sun?
- Has thanked: 24 times
- Been thanked: 58 times
nice picture Valery!
I'm also happy to see that you are alive Please contact me asap by private message or e-mail to my usual address (you know why of course)
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Great images as usual. I am still trying different post-processing techniques to achieve that "fluid" look ....
Alfred
Alfred
