Here comes the sun ! March 24th
- Has thanked: 9327 times
- Been thanked: 6163 times
Finally Spring is here and I was out with the scopes for the first time this year ! As always, at the beginning of the season my mount gave multiple error codes for a while. Then all of the sudden it started to work OK. The seeing was not great, weather was breezy, but I decided to take my chances.
Really the only feature was this butterfly shaped prominence that was fun to watch. I tried a high-res close-up but the seeing did not allow for a sharp image.
Thank you for looking !
- 123435-mono-2.jpg (158.62 KiB) Viewed 1460 times
- 123435-color-2.jpg (287.98 KiB) Viewed 1460 times
- Been thanked: 4434 times
Re: Here comes the sun ! March 24th
Hi Franco...
This worked out well, the detail in the proms is sharp
Trick is not to push too far when the conditions are tough and this seems to have been a good setup.
- Has thanked: 20828 times
- Been thanked: 10502 times
That's a nice image Franco!
- Has thanked: 8559 times
- Been thanked: 8297 times
Looking good there, Franco.
- rsfoto
- Has thanked: 9733 times
- Been thanked: 5777 times
Great details on the Prominence
regards
regards
Thank you Brian, Mark, Stu and Rainer for you nice comments.
- pedro
- Has thanked: 14 times
- Been thanked: 6696 times
Nice first season images Franco
Pedro Re'
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
Lovely!
Robert
Robert
- Been thanked: 4981 times
Thank you Pedro, Robert, Derek and Eric for your comments. This was done with the SM 90mm DS, 450 frames, 20% of which stacked, with the PG Flea 3 3.2 MP mono camera in Mode 7 at only 15 FPS (30 sec total capture time). Processed with Astra Image and PS.
- Been thanked: 8907 times
I'm glad you had the opportunity to blow the dust off, the prom shots are really crisp and lovely I don't see the butterfly though?
Hi Alexandra: thank you for your nice comments. I guess it looked more like a butterfly visually: in the images it looks to me more like a bent H.
