Much better seeing
Much better seeing
The high cloud layer was gone, the atmosphere was steadier, and there was a bright new prom (on the WNW side in this image) when I took a quick look after work yesterday.
Had to take a picture
Lunt LS80THa
ZWO ASI174MM
Lunt LS80THa
ZWO ASI174MM
Last edited by Bruce Girrell on Thu Mar 29, 2018 11:04 pm, edited 1 time in total.
- Has thanked: 17672 times
- Been thanked: 8793 times
Re: Much better seeing
The prom was quite bright when I first looked at it. It was fading as I made my full disk exposure. A mere 8 minutes later, only enough time to screw the 5x Powermate in place, refocus and readjust, and the prom had faded considerably.
I think they show up best if you click on the BW image
LuntLS80THA
5x Powermate
ZWO ASI174MM
LuntLS80THA
5x Powermate
ZWO ASI174MM
Thanks Alexandra
I tried reworking it today with some suggestions from Mark Townley's processing video. Two things in particular were helpful:
1) Flattening the brightness range of the image using a heavily median filtered copy of the image and
2) Keeping an eye on the histogram as you're making adjustments
Thanks Mark
I like the detail in the disk better, but I lost some in the proms. Flattening the image takes a little practice to see what works best. The simple Darken curve didn't work for me and I used the Curves dialog as normal, which produced a good result. You have to play a bit. I have always relied heavily on the histogram, but I hadn't realized that Photoshop's dedicated histogram window shows both the original and the result of your adjustment as you're doing it. Very helpful.
Thanks Mark
- Been thanked: 4904 times
- pedro
- Has thanked: 14 times
- Been thanked: 6578 times
Nice images Bruce. The LUNT80 is great
Pedro Re'
- Has thanked: 20442 times
- Been thanked: 10248 times
Nice images Bruce
Thanks all
And thanks for making your video tutorials, Mark. I should have mentioned your use of the iterative unsharp mask also. It is clear that a 10% USM, applied 10 times is superior to a 100% USM of the same size. Sometimes after applying the action, I find that the 10x is a little too much, but the History allows me to step back into the succession of USM applications and choose the sharpness that I like. Another advantage.
Last edited by Bruce Girrell on Tue Apr 03, 2018 1:16 am, edited 2 times in total.
Glad you find the tutorials useful Bruce
- Ronnie_Clayton
- Has thanked: 10 times
- Been thanked: 130 times
- Been thanked: 4340 times
Excellent capture and processing Bruce...well done
- Has thanked: 8418 times
- Been thanked: 8165 times
Nicely done, Bruce. Lovely prom images.
