AR12709 remnants close up in the Ca II K line.
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Hi all
Early morning of May 15 was a clear with a slow breeze. The seeing was variable from so so to good.
I deceided to image the sun in CaK first.
Equipment used: C11 280mm F/10 SCT on the EQ8 mount, ARIES full size 295mm two bands DERF,
PST CaK filter, Basler 1920-155 camera.
The Sun was blank and only a tiny remnants of the AR12709 group were seen. It looks best in the CaK line.
In the H-a it was hidden by the chromosphere and in a white light it looks like a tiny pore barely detectable
on the desert background.
Such a large scale 0,13"/pix is necessary for correct sampling at such a wave length.
Thanks for looking and comments.
Valtori
Has thanked: 312 times
Been thanked: 182 times
Re: AR12709 remnants close up in the Ca II K line.
Post by Valtori »
Hi Valery,
Very nice shot!! High resolution in CaK!
Val
Has thanked: 64 times
Been thanked: 4406 times
Post by MapleRidge »
Excellent resolution Valery :bow
You have the capture/processing techniques well adapted to this type of hi-res work.
Post by Valery »
MapleRidge wrote: Sun May 27, 2018 9:43 pm Excellent resolution Valery :bow
Brian, nothing special in capture&processing, really. If one has a proper equipment and is able to catch
seconds of good seeing, this all. The post processing is quite simple.
danpro1
Has thanked: 21 times
Been thanked: 29 times
Post by danpro1 »
Excellent!
Has thanked: 8523 times
Been thanked: 8251 times
AWESOME.... excellent image, Valery.
p1taylor
Has thanked: 1 time
Been thanked: 219 times
Post by p1taylor »
A really good shot.
peter
LUNT LS 60THa WITH PRESSURE TUNER, BLOCKING FILTER B1200, Skywatcher Startravel 80T OTA, ZWO ASI 178MM, lot of bit
Has thanked: 20732 times
Been thanked: 10427 times
Very impressive as always Valery!
LauraMS
Has thanked: 55 times
Been thanked: 81 times
Post by LauraMS »
Great image quality in near UV, Valery. Congratulations!
Best wishes
Laura
allhoest
Has thanked: 714 times
Been thanked: 496 times
Post by allhoest »
I like it.
CS
Alex
Has thanked: 17888 times
Been thanked: 8887 times
These CaK images you take are really special Valery :bow :bow
Post by Valery »
Ledies and gentlemen,
Just read your so positive commets. Thank you all.
best,
Been thanked: 4957 times
Post by eroel »
Valery:
Super image.
Best wishes,
Post by Valery »
Thank you, Eric!
BTW. When do you plan to start imaging with your 10" TEC Mak and 10" ARIES DERF?
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Post by GreatAttractor »
That's a great "diamond dust", Valery!
TheSkyBurner, that's an interesting comparison indeed.
My software:
My images
Post by Valery »
GreatAttractor wrote: Sun Jun 03, 2018 2:37 pm That's a great "diamond dust", Valery!
Khe Khe... diamond dust? Thanks for such an unusual allegory.
