Sunday Sun 3rd June_RCT_Ha
Has thanked: 8523 times
Been thanked: 8253 times
Lovely blue skies although with a hint of cloud building in the North and East and some haze starting to develop right where it shouldn't :evil:
RCT with the Lunt 35
IMG_3708 (2).JPG (181.17 KiB) Viewed 2277 times
IMG_3709 (2).JPG (122.37 KiB) Viewed 2277 times
and for Valery, the almost 'zero' movement on the thumbscrew under today's conditions.
IMG_3710 (2).JPG (211.82 KiB) Viewed 2277 times
AR2712 close to the limb in Mono and Colour.
AS!3, Imppg and Pixinsight with Basler acA1920-155um + 2.5x Powermate.
Image20180603_AR2712_RCT_Mono by Stuart Green, on Flickr
Image20180603_AR2712_RCT_Colour by Stuart Green, on Flickr
Best viewed as the 'original' from Flickr.
The session was paused as I waited for the haze (precipitated from a contrail) to pass..... long wait!!
Thanks for looking.
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Re: Sunday Sun 3rd June_RCT_Ha
Post by GreatAttractor »
Great resolution, Stu. I love the looks of the setup too.
My software:
My images
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Hi Stu,
The result is clearly better than all before! Nice processing too.
I noted that you do use some oversampling. The image scale you do use with a 10" scope is significatly larger
than I do use with my 11" scope. Smaller scale will makes imaging easier - shorter exposure, larger FOV, better
seeing freezing and faster fps. I would recommend F/18-20 for a camera with IMX174 chip.
CS
Has thanked: 20756 times
Been thanked: 10441 times
Nice to see the pics of your setup Stu, looks like it's delivering the goods. I got the HaT out first thing this morning but seeing was mush so put it straight away.
Has thanked: 1179 times
Been thanked: 1370 times
Post by MalVeauX »
Interesting setup, I'm curious about how to rear-mount fast focal-ratio etalons behind larger scopes, be they SCT or refractor (though mainly interested in SCT at the larger apertures for compactness and weight). Especially finding a way to use a 50mm or 60mm etalon, instead of a PST etalon to avoid the quality of copy variation in the PST etalons, or simply getting a double stack unit and using that behind a larger scope, if possible. Would love to know more.
rsfoto
Has thanked: 9690 times
Been thanked: 5759 times
Post by rsfoto »
WOW amazing images and interesting set up
Been thanked: 4958 times
Post by eroel »
Stu:
Beautiful setup and results.
Has thanked: 17925 times
Been thanked: 8894 times
Some superb detail there Stu, looking good!! :bow :hamster:
Has thanked: 9296 times
Been thanked: 6131 times
Post by ffellah »
Great images, Stu and beautiful looking set-up.
Many thanks everyone for your kind comments. Like all these things, practice and homing in on things that work are what count.....and I'm still learning! AR2712 is/was a particularly spectacular target with loads of dramatic structures on a large scale.
Valery wrote: Sun Jun 03, 2018 1:54 pm Hi Stu,
CS
Thanks for your feedback, Valery. I processed these using the re-sampling x2 function in Autostakkert 3 which made the image quite large, but my thinking was that this would yield finer detail in the stacked image. Maybe I should use 2x2 binning to reduce the exposure time as well.
I think the scope is running at about F35 with a 2.5x Powermate. Maybe I should use a 1.5x barlow instead to bring it closer to F20.... more experimentation to be done. I was just so pleased to be able to capture something worthwhile before the sky conditions deteriorated.
Valtori
Has thanked: 312 times
Been thanked: 182 times
Post by Valtori »
Hi Stu,
Very pleased results with such aperture!!
Val
MalVeauX wrote: Sun Jun 03, 2018 6:11 pm Interesting setup, I'm curious about how to rear-mount fast focal-ratio etalons behind larger scopes, be they SCT or refractor (though mainly interested in SCT at the larger apertures for compactness and weight). Especially finding a way to use a 50mm or 60mm etalon, instead of a PST etalon to avoid the quality of copy variation in the PST etalons, or simply getting a double stack unit and using that behind a larger scope, if possible. Would love to know more.
Hi Marty,
I employ a collimating lens mounted inside the rear of the scope of an appropriate focal ratio to produce parallel rays for the etalon. The Lunt 35 seems to work quite well since the etalon(s) are front mounted.
