Sol from the 4th of June 2018.
Post by eroel » Tue Jun 05, 2018 1:45 pm
Hi:
The usual CaK and Ha FD´s, taken with the Meade 102mm f/9 with a CaK PST mod and the Solarmax 90-DS.
Thanks for looking,
Sol del 4 de junio de 2018-Meade-CaK-PSTmod-1an.jpg (787.67 KiB) Viewed 944 times
Sol del 4 de junio de 2018-Meade-CaK-PSTmod-1inv.jpg (817.94 KiB) Viewed 944 times
Sol del 4 de junio de 2018-Meade-CaK-PSTmod-2an.jpg (603.1 KiB) Viewed 944 times
Sol del 4 de junio de 2018-Meade-CaK-PSTmod-2inv.jpg (627.92 KiB) Viewed 944 times
Sol del 4 de junio de 2018-Solarmax 90-DS-BF30-1an.jpg (859.02 KiB) Viewed 944 times
Sol del 4 de junio de 2018-Solarmax 90-DS-BF30-1inv.jpg (918.03 KiB) Viewed 944 times
Sol del 4 de junio de 2018-Solarmax 90-DS-BF30-2an.jpg (911.74 KiB) Viewed 944 times
Sol del 4 de junio de 2018-Solarmax 90-DS-BF30-2inv.jpg (920.06 KiB) Viewed 944 times
Valtori
Re: Sol from the 4th of June 2018.
Post by Valtori » Tue Jun 05, 2018 1:56 pm
Hi Eric,
Lovely FDs there!!
Val
Post by eroel » Tue Jun 05, 2018 3:10 pm
Val:
Thank you.
Looks like the bright prominence shown at 11:00 in the Ha FD´s, did not show on the CaK ones, probably was not energetic enough.
In the CaK prominence FD`s, it is barely shown.
Post by marktownley » Wed Jun 06, 2018 1:47 pm
Super disks Eric!
Post by Montana » Thu Jun 07, 2018 6:43 am
A lovely collection Eric, it is sad to see AR12712 disappear but there are some large proms in the east, we can only hope they are associated with something new :)
:bow :hamster:
Post by ffellah » Fri Jun 08, 2018 12:06 am
I always admire your high contrast disks, Eric.
allhoest
Post by allhoest » Sun Jun 10, 2018 7:40 pm
Eric, I'm passing trough the posts.
I wonder the CaK proms on your pics.
Congrats!
CS
Alex
Post by Carbon60 » Mon Jun 11, 2018 5:52 am
Excellent images, as always, Eric; lots of contrast and detail.
There appears to be a 'seam' around the Sun in the third (and inverted fourth) image. Is this some sort of long range structure, I wonder?
Stu
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by eroel » Mon Jun 11, 2018 2:30 pm
Alexandra and guys, thanks for the comments.
Stu, I also saw that. BTW, you can see it in all the FD´s in CaK and in Ha, in some shots it looks much fainter.
In my workflow I always change the recording parameters on each FD, so that is why in some FD`s you can see more or less details.
The seam could be an alignment issue, I take always 1000 frames in SER at 12fps (that is as fast as the SKYnyx 2-2 goes at full resolution) and use 30% of them to make the final version.
Best regards to all,
Post by Carbon60 » Tue Jun 12, 2018 11:20 am
Hi Eric,
At what times were your CaK images captured on June 4th (in UT rather than local)?
Regards
Stuart
NEQ6 Pro-mount
Post by eroel » Tue Jun 12, 2018 3:40 pm
Stu:
I will check today and let you know.
Post by eroel » Tue Jun 12, 2018 5:55 pm
Stu:
The first CaK "surface" SER recording was taken at 17:38 UTC.
The first CaK prominence SER recording was taken at 12:42 UTC.
The second CaK "Surface" SERrecording was taken at 12:46 UTC.
The second CaK prominence SER recording was taken at 12:49 UTC.
Thanks, hope it helps for what you are thinking.
Best wishes,
Post by Carbon60 » Wed Jun 13, 2018 6:57 pm
Thanks, Eric. I was curious to see what SDO recorded at the same time.
I believe it is a real feature, rather than an image artefact. Maybe it's the result of some random alignment, or maybe it was nucleated at AR12712.
Thoughts anyone?
NEQ6 Pro-mount
Post by eroel » Wed Jun 13, 2018 7:01 pm
Stu:
When some time left, I will realign and restack again the SER files in different softwares, (Registax6 and AS!2 and AS!3) so to find if it is an alignment and stacked artifact.
Users browsing this forum: No registered users and 4 guests
