Sol from the 4th of June 2018.
Post by eroel » Tue Jun 05, 2018 1:45 pm
Hi:
The usual CaK and Ha FD´s, taken with the Meade 102mm f/9 with a CaK PST mod and the Solarmax 90-DS.
Thanks for looking,
Sol del 4 de junio de 2018-Meade-CaK-PSTmod-1an.jpg (787.67 KiB) Viewed 839 times
Sol del 4 de junio de 2018-Meade-CaK-PSTmod-1inv.jpg (817.94 KiB) Viewed 839 times
Sol del 4 de junio de 2018-Meade-CaK-PSTmod-2an.jpg (603.1 KiB) Viewed 839 times
Sol del 4 de junio de 2018-Meade-CaK-PSTmod-2inv.jpg (627.92 KiB) Viewed 839 times
Sol del 4 de junio de 2018-Solarmax 90-DS-BF30-1an.jpg (859.02 KiB) Viewed 839 times
Sol del 4 de junio de 2018-Solarmax 90-DS-BF30-1inv.jpg (918.03 KiB) Viewed 839 times
Sol del 4 de junio de 2018-Solarmax 90-DS-BF30-2an.jpg (911.74 KiB) Viewed 839 times
Sol del 4 de junio de 2018-Solarmax 90-DS-BF30-2inv.jpg (920.06 KiB) Viewed 839 times
Valtori
Re: Sol from the 4th of June 2018.
Post by Valtori » Tue Jun 05, 2018 1:56 pm
Hi Eric,
Lovely FDs there!!
Val
Post by eroel » Tue Jun 05, 2018 3:10 pm
Val:
Thank you.
Looks like the bright prominence shown at 11:00 in the Ha FD´s, did not show on the CaK ones, probably was not energetic enough.
In the CaK prominence FD`s, it is barely shown.
Post by marktownley » Wed Jun 06, 2018 1:47 pm
Super disks Eric!
Post by Montana » Thu Jun 07, 2018 6:43 am
A lovely collection Eric, it is sad to see AR12712 disappear but there are some large proms in the east, we can only hope they are associated with something new :)
:bow :hamster:
Post by ffellah » Fri Jun 08, 2018 12:06 am
I always admire your high contrast disks, Eric.
allhoest
Post by allhoest » Sun Jun 10, 2018 7:40 pm
Eric, I'm passing trough the posts.
I wonder the CaK proms on your pics.
Congrats!
CS
Alex
Post by Carbon60 » Mon Jun 11, 2018 5:52 am
Excellent images, as always, Eric; lots of contrast and detail.
There appears to be a 'seam' around the Sun in the third (and inverted fourth) image. Is this some sort of long range structure, I wonder?
Stu
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by eroel » Mon Jun 11, 2018 2:30 pm
Alexandra and guys, thanks for the comments.
Stu, I also saw that. BTW, you can see it in all the FD´s in CaK and in Ha, in some shots it looks much fainter.
In my workflow I always change the recording parameters on each FD, so that is why in some FD`s you can see more or less details.
The seam could be an alignment issue, I take always 1000 frames in SER at 12fps (that is as fast as the SKYnyx 2-2 goes at full resolution) and use 30% of them to make the final version.
Best regards to all,
Post by Carbon60 » Tue Jun 12, 2018 11:20 am
Hi Eric,
At what times were your CaK images captured on June 4th (in UT rather than local)?
Regards
Stuart
NEQ6 Pro-mount
Post by eroel » Tue Jun 12, 2018 3:40 pm
Stu:
I will check today and let you know.
Post by eroel » Tue Jun 12, 2018 5:55 pm
Stu:
The first CaK "surface" SER recording was taken at 17:38 UTC.
The first CaK prominence SER recording was taken at 12:42 UTC.
The second CaK "Surface" SERrecording was taken at 12:46 UTC.
The second CaK prominence SER recording was taken at 12:49 UTC.
Thanks, hope it helps for what you are thinking.
Best wishes,
Post by Carbon60 » Wed Jun 13, 2018 6:57 pm
Thanks, Eric. I was curious to see what SDO recorded at the same time.
I believe it is a real feature, rather than an image artefact. Maybe it's the result of some random alignment, or maybe it was nucleated at AR12712.
Thoughts anyone?
NEQ6 Pro-mount
Post by eroel » Wed Jun 13, 2018 7:01 pm
Stu:
When some time left, I will realign and restack again the SER files in different softwares, (Registax6 and AS!2 and AS!3) so to find if it is an alignment and stacked artifact.
