First light with C8 Edge scope.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hello Everyone.
A long absence but I'm getting my feet wet with solar imaging again. I've invested in a C8 Edge scope and Point Grey camera with IMX174 CMOS chip so I'm looking forward to high frame rates and some success with high resolution imaging. Here are some first light shots. There's not much to see but I think the results bode well for the return of some solar activity down the line.
Peter.
Peter.
- Has thanked: 9387 times
- Been thanked: 6199 times
Re: First light with C8 Edge scope.
Great surface shots with very nice detail, Peter. Very nice set-up also. Welcome back to this wonderful group.
- Ibbo
- Has thanked: 2472 times
- Been thanked: 1666 times
Looks a nice setup and you should be well set for an increase in surface activity.
Impressive setupt, Peter! And very nice resolution on the images.
However they looks somewhat overexposed on both my monitors. And I tried to make the second image a bit less bright and it shows more details. Hope you don't mind it.
- PZ-2.png (2.41 MiB) Viewed 1892 times
- Dave S
- Has thanked: 5 times
- Been thanked: 19 times
Great first shots, and an impressive imaging train! I can't wait to see more of your work.
I agree with Valery, reducing the exposure should yield more detail.
- Has thanked: 20940 times
- Been thanked: 10587 times
That's an excellent image Peter, and a very nice setup too!
- Has thanked: 18105 times
- Been thanked: 8941 times
Wow! super images, looking forward to more from this set up
- p_zetner
Thanks everyone for your very kind comments!
Valery: You’re right. There is more detail visible with the reduced exposure, although it still looks a touch too dark on my (uncalibrated) monitor. I have to control my inclination to push the contrast too far!
Peter,
You are correct. My interpretation of the image is a bit too dark. But this is because there is a limit of the dymanic range of the finished JPEG image. Really the best compromise is somewhere between.
I too took a lot of movies which looked good when I recorded them at the telescope in a full day light. But they were a bit overexposed when I process them in a usual room illumination be it window illumination or evening lamp illumination. It took some time correct this and now I recording the movies with a histogram filled for about 60% max.
But the main result of your images is that this setup works great and the resolution is remarkable, so your location is OK seeing wise.
Looking for more images from you.
- Has thanked: 1 time
- Been thanked: 2725 times
Hello Peter,
Your first tests look very promissing !!
Best regards
Christian
Best regards
Christian
- Been thanked: 5016 times
Peter:
Beautiful results and a beautiful setup too.
