Solar transit composite photo tutorial?
Albuqshutterbug
Been thanked: 26 times
Post by Albuqshutterbug »
Has anyone put together a quick and easy tutorial for making composites of transits?
If so, where would one find them?
Thanks in advance.
Jim
Lunt pressure tuned 60mm with 1200 blocking filter.
And Baader 5D solar film filters for all of my lenses and telescopes.
For Imaging:
Celestron Skyris 236M and 236C
Canon 7D, Canon 5D Mark II and Canon T2i IR Modified
Has thanked: 20750 times
Been thanked: 10439 times
Re: Solar transit composite photo tutorial?
Can't help sorry! Never got a transit...
PDB
Has thanked: 2 times
Been thanked: 149 times
Post by PDB »
Hi Jim,
have been asked that question myself a few times. I was able to shoot one Moon transit last year, but never got the composite image right.
Now I found this page http://www.thelondonastronomer.com/it-i ... ce-station
Rgrds,
Albuqshutterbug
Exactly what I was looking for .. simple and to the point.
I will need to tweak but here is a first attempt.
Thank you very much for taking the time to share this.
Jim
composite color 2.jpg (2.72 MiB) Viewed 1926 times
For Imaging:
Has thanked: 17925 times
Been thanked: 8894 times
That's a great tutorial, exactly the same way as I have done it in the past. Great composite Jim :hamster:
That's a great result!
I think one for the library in a day or so...
Albuqshutterbug
Thank you very much Alexandra.
I was pleased with my image of the sun but the ISS looks a bit odd. I think it may have been atmospheric distortion due to high winds at the surface and aloft.
I am still quite pleased with the results.
For Imaging:
Albuqshutterbug
Thank you Mark.
Yes I think this site should at least be linked.
It has quite a bit of good information.
Jim
For Imaging:
PDB
Post by PDB »
Just one remark I would like to add. If you capture to SER files instead of AVI you can also extract the images with SerPLayer. Very easy, play the video in SER player until you see the "action". Pause, go back to the first frame with the ISS, write down the frame nummer. Go forward and mark the last frame you want to extract. Then from "file"-> save frames as images enter the frame range and save (use TIF for further processing). You will get 1 file per frame
Albuqshutterbug
Thank you Paul for the suggestion.
The Celestron Capture software iCap only saves as AVI and I have had the best captures with this software. Perhaps I need to learn the sniggy details of FireCapture or AstroCap.
I did download the SerPlayer software for future endeavors.
Jim
For Imaging:
