Hi all...
It took a few hours this afternoon to finish processing the balance of the images collected of Sunday. As mentioned in the first post I had a set imaged through the 5x Powermate, but I also had some Ha sets that were imaged in the red and blue wings. I'll start with the 5x series, taken through the modded CR150/DSII/B1800Ha + 5x Powermate + ZWO174MM camera.
The first region was the emerging active region on the eastern limb, first imaged with the DSII etalon set at 0 PSI which shows a wide Ha band:
The next series have the etalon tuned to the midpoint of the Ha:
The image below is the remains of AR2717 with the tuned etalon (my continuum image did not work out):
The following images used the same setup, but with a 3x tele-converter. I adjusted the pressure in the DSII etalon to image the red and blue wings of the Ha line. Each region is shown in the following order...Red Wing/On-Band/Blue Wing, starting on the eastern limb:
The last region is the remains of AR2717:
This should finish off the session from Sunday. Another round to process from today, but they will be a few days before they are all processed and posted.
August 5th - Part 2
- Been thanked: 4340 times
August 5th - Part 2
- 3x_CR150_DSII-15_102408-ASI.jpg (926.14 KiB) Viewed 949 times
- Has thanked: 8418 times
- Been thanked: 8163 times
Re: August 5th - Part 2
A great set of images, Brian. You had a very busy session.
- Has thanked: 17672 times
- Been thanked: 8792 times
Another great set, I like the wing comparisons a lot. I always forget to do this and yet it is always interesting when I see others do it.
- Has thanked: 9145 times
- Been thanked: 6025 times
Nice session, Brian!
Hope you will have many clear sunny days with a good seeing like this one.
- Has thanked: 20442 times
- Been thanked: 10247 times
Loving all this imaging you're getting in Brian!
Stu, Alexandra, Franco, Valery, and Mark...
Many thanks to each of you for the comments and feedback...always appreciated
