Sun in Ha and CaK 25th Aug
- Has thanked: 8543 times
- Been thanked: 8278 times
The weather reports were a bit ambiguous as to whether we'd have sunshine or not, so I did what most of us probably do which is to cross fingers and simply look out of the window in the morning. To my delight......blue sky (well, mostly).
I felt confident enough to set up the 250mm RCT in Ha, but after 20 minutes of trying, I couldn't obtain anything worth keeping and all my data using this scope ended up in the bin. I switched to the DS150mm Ha (modified Lunt 35) and things were much better, but again not ideal and the images were lacking bold detail. Nevertheless there were some worth keeping and these are shown below. There are a couple of nice looking active regions (AR2719 and AR2720) with a little bit of crackling activity through AR2720. Some modest proms were on display, which I tried to capture using the same scope. I switched to the DS Lunt 60 Ha for a full disk and then over to my 72mm/f6 with a Lunt CaK B600 module for a full disk in CaK. I also managed a closer view of the active regions in CaK.
Here are the results:
20180825_Ha1_FD_mono by Stuart Green, on Flickr
20180825_Ha1_FD_Colour by Stuart Green, on Flickr
A closer view of the two active regions (should have flipped the image!)
20180825_Ha_AR2719_AR2720 by Stuart Green, on Flickr
and a closer view (cropped image) of AR2720. Not ideal....
20180825_Ha_AR2720 by Stuart Green, on Flickr
A couple of proms.... You'll see that my DS tuning was a bit off
20180825_Prom1 by Stuart Green, on Flickr
20180825_Prom2 by Stuart Green, on Flickr
Then over to the blue and a CaK full disk
20180825_CaK_FD_Mono by Stuart Green, on Flickr
20180825_CaK_FD_Colour by Stuart Green, on Flickr
and finally a closer view of the active regions in CaK. This was taken with a 5x TV Powermate on the 72mm refractor.
20180825_CaK_AR2719_AR2720 by Stuart Green, on Flickr
That was the end of the session. Clouds rolling in and a busy schedule ended any chance of doing anything more.
Thanks for looking.
Thanks for looking.
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Re: Sun in Ha and CaK 25th Aug
Beautiful set Stu.
Best wishes,
David
Best wishes,
David
- Has thanked: 17970 times
- Been thanked: 8904 times
What a super active region!! the spots have really developed and look beautiful in both lights you are so lucky to get Sun this weekend, the rain seems to be parked over Manchester and Cheshire like a bad rash this weekend and it is dire weather.
Thanks for the beautiful views
Many thanks David and Alexandra. The clear weather was really unexpected. I tried to make the most of it, despite the poor seeing conditions.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
These are very nice, Stu. The high resolution H alpha shots are quite good considering your seeing challenges.
Cheers, Peter.
Cheers, Peter.
Many thanks, Peter. The seeing conditions are the limiting factor in most cases, for me. Good seeing is far too infrequent.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Beautiful pictures, Stu, your H alpha picture are really impressive and very sharp.
Many thanks, Raf and Pepe. Much appreciated.
Stu
Stu
Nice set of images, Stu!
Too bad the sun is blank again.
- Has thanked: 9307 times
- Been thanked: 6144 times
Many thanks, Franco.
Stu
Stu
Missed this one. Many thanks, Valery.
- Has thanked: 20779 times
- Been thanked: 10462 times
Missed these Stu! very nice.
