Sun is still very quiet, there are no major details on the disc not even the smallest pore. Just to keep my telescopes working I have taken a picture of the full disc and a close up of one of the few interesting parts of the chromosphere.
The BF of my Daystar Calcium suffered a degradation of the "glue" or jelly used to stick together its two elements, the clear UV/IR glass and the blue one. I expected such a failure but not soon. As I have absolutely not intention to send it to the other side of the Atlantic for service I am looking for a suitable replacement material. I have several solutions used in microscopy for preparing permanent slides but I do not know if they can be used in this case. For the moment I cleaned the glasses and put them again in the barrel and I noted that the device seems to be working normally.
Quiet Sun in Ca-H
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Quiet Sun in Ca-H
- 2018-09-03-0836-RB-CaH.jpg (682.95 KiB) Viewed 947 times
- 2018-09-03-0836-RB-CaH-fulldisc.jpg (392.33 KiB) Viewed 1002 times
- Has thanked: 9318 times
- Been thanked: 6156 times
Re: Quiet Sun in Ca-H
Nicely done, Raf ! A beautiful but quiet disk and the close-up showing the more active region in detail.
- Been thanked: 8906 times
Superb images
I'm sorry to hear about the Quark problems, it doesn't surprise me though
- krakatoa1883
Thanks Franco, Alexandra
However, I replaced the clear glass of the BF - the IR-eater I suppose, with an Astronomik UV/IR cut plus a single stacked Baader K-line, this way the system works fine but I have to look around for a better device, probably a Lunt K module.
I too am not surprised this is the second Quark I had to dismantle/modify to make it working, such a bad experience never again... cheap Daystar products are definitively not for me.
Nice images. However the nature of the CaK and CaH structures make them looks dramatical at a much larger scale than in H-a. Thanks to shorter WL of the CaK/H we can make the scale 1,7x larger (vs H-a scale) without a sharpness degradation. Your Mewlon can become a real monster at this WL when used at it's scale limit - equal in resolution to a C14 working in H-a!
- Has thanked: 20813 times
- Been thanked: 10484 times
Good job there Raf! Hope that filter behaves itself.
