Prominence Hedgerow Animation
- Has thanked: 9145 times
- Been thanked: 6025 times
- Has thanked: 17672 times
- Been thanked: 8792 times
Re: Prominence Hedgerow Animation
I must say that is terrific work! took a while to load but definitely worth the wait. There is so much going on from tornadoes to surges. Absolutely fabulous, well done
However, why is the detail so fine in the animation but not replicated in the single image? I think you need to pick your sharpest frame.
- Been thanked: 4904 times
- Dave S
- Has thanked: 5 times
- Been thanked: 19 times
Thanks for pointing that out, Alexandra. I'm looking into that, which is a helpful exercise. There were a lot of differences, including different capture time, tweaked focus, different exposure time, different processing flow due to the need for automation... and the ability to throw out some blurry frames from the animation.
Thanks for the kind comments!
- Has thanked: 8418 times
- Been thanked: 8163 times
Nice work, Dave. Lovely animation sequence. There's lots going on there, even the small stuff on the limb.
- Been thanked: 4340 times
That is one awesome animation Dave
- Has thanked: 20442 times
- Been thanked: 10247 times
That's excellent Dave!
- robert
- Has thanked: 4 times
- Been thanked: 1274 times
Beautifully done
