Good day everyone...
A return of sunny weather this past weekend, but only time to try imaging on Sunday morning. Disk activity was limited with a few small filaments above it, while the main attractions were the proms along the limb. The image below is a disk/limb composite (limb inverted) taken through the LS80T/LS75FHa/B1200Ha and PGR camera (ICX674 chip):
The seeing wasn't working to my advantage, but I tried to get some of the features in higher resolution with a 3x tele-converter and I swapped the ZWO 174MM camera to capture these images. These small mosaics cover the north-eastern and north-western quadrants:
There were 3 main areas of prominences visible, and there is an image to highlight each below. First is the NE limb area:
The next is on the NW limb:
The final image is along the western limb, but the longer exposures did not capture the small loop prom that was noticed on the full disk image. It shows a bit better in the inverted version:
That pretty much covers the morning efforts. Questions and comments are always welcome.
September 23rd Session
- Been thanked: 4434 times
- Been thanked: 8907 times
Re: September 23rd Session
Thanks Alexandra
At least you got some Sun Brian despite the seeing.Very busy here looks like a below average year for Honey production down here mind you the wholesale price hasn’t, shot up.Take care.
Derek
Derek
- Has thanked: 9327 times
- Been thanked: 6163 times
- Been thanked: 4981 times
Brian:
In spite of seeing, it was a very good session.
Best wishes,
Best wishes,
- Has thanked: 20825 times
- Been thanked: 10499 times
Great images Brian!
Franco, Eric, and Mark...
Thanks to each for your comments. Always appreciated
