Impact of telescope height on the seeing
- Has thanked: 1 time
- Been thanked: 2725 times
Dear all,
Some time ago, I tried to measure the impact of the height of the telescope on the seeing. I compare the seeing at ground level and 1 m high.
Since I had only one SSM, the measurements at 0 m and 1 m where not simulaneous. Still some impacts are clearly visible:
Last August, Karine Chevalier carried out measurements at St Veran using two SSM. The seeing was measured simultaneously at 1 m and 1.5 m high, which is typical of telescope aperture heigths.
The ground at St Véran is made of rocks with no grass. The mesurements were made over a period of time of more than one hour.
Karine, whom I thank for, made the measurements and the data reduction. Here are the results :
This graphic gives the % of time below a given value of seeing :
The table is another way to present these results :
In a nutshell, it means that going from 1 m to 1.5 m high improves the seeing by about 0.35 arcsec, which is ... quite significant.
In high resolution imaging, we typically keep less than 5% of the frames. We can see on the table that the quantile 5% goes from 0.7 to 0.3 arcsec when the aperture of the instrument rises from 1 m to 1.5 m high.
So now, we all have to use tall tripods :-)
PS : of course, all of this depends on wind speed, ground nature, hour in the day, etc.
Best regards
Christian
Best regards
Christian
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Re: Impact of telescope height on the seeing
Very interesting Christian. I suppose height is relative to the ground on which the telescope rests, irrespective if the ground is at sea level or 2000 m a.s.l., am I right ? (anyway I would expect a generally better seeing at 2000 m...)
Yes indeed, this is the height relative to the ground.
- Has thanked: 9327 times
- Been thanked: 6163 times
Great to know, Christian. Thank you for sharing this with all of us.
- Has thanked: 1192 times
- Been thanked: 1387 times
Interesting stuff, I imagine it is different for different thickness optics and different types of ground (field of soil & grass, compared to desert or straight rocks, sedimentary soil versus hot quartz sand, etc).
I keep my instruments up on a pier, fairly high up, and my decking in the observatory is over the soil.
I wonder if it would matter for those using tripods, if they put a thermal barrier (like covers used to block solar) on the ground under the telescope's aperture/mirror?
At home, I observe on a ground covered by grass, and I spray water on the grass during observation.
- Been thanked: 4981 times
Christian:
Very interesting information, my Mexico City home observatory is 2246 meters above mean sea level, the rural observatory is at 2265 meters above mean sea level.
So I don´t need a high pier. , but in the City the problem is air contamination, at the rural place I have a very even and clean seeing.
- Been thanked: 8907 times
Very interesting! however I am barely tall enough to mount my telescope at 1m
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
Excellent clear results and presentation, thanks
Robert
Robert
- Has thanked: 20834 times
- Been thanked: 10503 times
Excellent and informative as always Christian!
We all know well about british grass lawns!
My SCT scopes are about 1,2 - 1,6m elevation (entrance aperture) above a grassy lawn level.
- pedro
- Has thanked: 14 times
- Been thanked: 6697 times
Great stuff Christian. My mount is over 2m in height but it is inside the dome...
Pedro Re'
- Has thanked: 128 times
- Been thanked: 121 times
Very interesting results and very well presented.
What do you feel might explain that much difference? Dust in the air layer just above the ground or perhaps some other form of scattering phenomenon? Thermal currents close to the ground?
Bruce G
Bruce G
I'll give this a few more days here then move over to the library folks, I think is a useful thread for reference.
Hello Bruce,
We used two AiryLab SSM.
We also started a session with three SSM running at 1, 1.5 and 2 m high, but this session was quickly clouded.
The inhomogeneities of the air in the boundery layer depens on the wind speed, type and temperature of the ground.
I am planning to make some tests at home in order to check whether there is a general pattern or not.
Those interested in this topic may wish to check out the following document:
THE EFFECT OF THE LOCAL ATMOSPHERIC ENVIRONMENT ON ASTRONOMICAL OBSERVATIONS
http://www.eso.org/gen-fac/pubs/astclim ... node1.html
In particular, note the following page
Surface layer seeing
http://www.eso.org/gen-fac/pubs/astclim ... ode75.html
This work is largely derived from the author's experience on the design and engineering of the ESO Very Large Telescope (VLT) observatory between 1984 and 1993. Thus, the focus is on large telescopes, not amateur, but the effect being studied is the same.
The Hypertext version is here: http://www.eso.org/gen-fac/pubs/astclim ... hesis.html
Note that the Hypertext version, while conveniently indexed, may be missing some figures
