10-13-2018 Ar2724 - Triple iron arch's
Has thanked: 156 times
Been thanked: 893 times
Re: 10-13-2018 Ar2724 - Triple iron arch's
Post by Valery »
What this (this sample) filter exact data? What is the telescope and full imaging train?
I see the arc in the center near the spot. But it is difficult to say what the real nature of it.
Has thanked: 1142 times
Been thanked: 1329 times
Post by MalVeauX »
Interesting.
I'm always curious how filaments in various wavelengths compare as filaments seen from above, hovering over the surface, compared to the same filaments on a limb with the void of space behind them, in various wavelengths, and why it's so hard to see them there when the should likely be more easy to spot and image, compared to a filament on the surface.
393nm or 540nm?
Has thanked: 20229 times
Been thanked: 10111 times
Very good Apollo! Ferrets are definitely real, I see them with my CaK setup too.
