Today was moderately clear weather, high pressure but showers and a gusty wind. The sun only getting to just over 20 degrees altitude. However I have been noticing that the SSM shows quite good readings despite all this at around 1 arcsec. So I tried the SW200 (f1000mm) Newtonian with ND3.8, Baader continuum, UV/IR cut and two different lenses, Celestron x3 and Televue x5.
TVx5
1017 17_Oct_18_113952_lapl4_ap621-30f_out by robertarnold, on Flickr
Cel x3
1017 17_Oct_18_113551_lapl4_ap378-30f_out by robertarnold, on Flickr
500 frames in Firecapture, 30 stacked in AS2, ImPPG to sharpen, PS2 to adjust and save as jpg
Robert
17th October WL granulation
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
- Been thanked: 4419 times
Re: 17th October WL granulation
Hi Robert...
Both images look great considering the low elevation of the sun
The 3x is very sharp, but the 5x still looks very good. A 4x might have delivered a bit more resolution but still excellent results.
- Has thanked: 9307 times
- Been thanked: 6143 times
- Has thanked: 20779 times
- Been thanked: 10462 times
Stunners Robert! Great results.
- Has thanked: 8543 times
- Been thanked: 8278 times
Very nice images, Robert. I prefer the second, but both are good.
Stu
Stu
- pedro
- Has thanked: 14 times
- Been thanked: 6688 times
Great results there Robert
Pedro Re'
- Been thanked: 4971 times
- robert
Thanks for the comments. Its the seeing that makes it work.
