Sun today 110418
- Has thanked: 9143 times
- Been thanked: 6024 times
Sun today 110418
Hello all: I was out this morning trying first high res but seeing would not allow it. I then took out the old trustworthy SM90DS and the PG Flea 3 3.2 MP and was able to get something. I got the Firecapture software to work with the SSM for the first time and it was a pleasure seeing it working in automatic.
I am still looking through the data to see what else came out...
Clear skies,
Clear skies,
- 101958 final mono.jpg (892.89 KiB) Viewed 2600 times
- 101958 final color.jpg (1.2 MiB) Viewed 2600 times
- 102808 final color.jpg (2.39 MiB) Viewed 2600 times
- Been thanked: 4340 times
Re: Sun today 110418
Very good results with the poor seeing limiting your efforts
- rsfoto
- Has thanked: 9401 times
- Been thanked: 5558 times
Hi Franco,
Very nice images. Now we know why it is called Solar Minimum but reading some news it looks like it will not last that long as it did before this Solar cycle. Hopefully it is true ... but the Sun always has surprises
Rainer
Rainer
- Has thanked: 17648 times
- Been thanked: 8787 times
Beautiful processing! it looks like a little hot spot on the disc and the proms are super too
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Good images, Franco, lovely processing.
Thank you Brian, Rainer, Alexandra and Raf for your nice comments, always appreciated
- Been thanked: 4904 times
Franco:
A very nice session in spite of seeing.
Where can I find some info on how to use the SSM in automatic with FireCapture?
Best wishes,
Best wishes,
Thank you, Eric. I will email you separately the instruction manual for the SSM Firecapture plugin installation and operation. Mark Townley is the one who pointed me to it. It is now my preferred combination capture and SSM control software. It works beautifully for me.
Franco:
Thank you very much.
Probably will have to change to my other cameras, I don´t know if FireCapture does control the SKYnyx 2-2.
Hi Eric...
I don't see the Lumenera cameras listed on the Firecapture support list. I still have several Lumenera cameras and wind up using Lucam to control them, but Heiko isn't doing any updates that I am aware of.
Franco:
I haven´t heard of Heiko since long, so I use the old Lucam for my 2 Lumeneras and 5 TIS.
It is a nice and easy software.
For the ZWO174 and QHY I use FireCapture.
- Has thanked: 20424 times
- Been thanked: 10242 times
Those are lovely shots Franco!
- Has thanked: 8415 times
- Been thanked: 8161 times
Very nice indeed, Franco.
Great to see your pic posted as the SPOD...well done
Thank you Mark, Stu, Eric and Brian for your nice comments. I am humbled by the SPOD.
- rsfoto
MapleRidge wrote: ↑Mon Nov 05, 2018 3:52 pm Hi Eric...
Hi Brian,but Heiko isn't doing any updates that I am aware of
That is correct. He started a project called Public Telescope but so far not much happened and he did totally let down Lucam Recorder. I did a lot of beta testing with him and also contributed a lot to the features of Lucam Recorder. SO far it is still the ebst software but unfortunately it only supports Lumenera and The Imaging Source cameras...
It is a pity he just let it go down and did not add more cameras.
Rainer
Here some news about it https://www.ohb.de/en/news/ohb-venture- ... trofactum/
