Possibly one of the last active regions of cycle 24? AR12757 ends january with decent activity for solar minimum. Taken by Marty Wise with his 8" SCT, Aries ERF and PST mod.
New Sunspot (Undesignated ATM), Big Proms, Full Disc | HA | Nov 9th 2018
Post by MalVeauX » Fri Nov 09, 2018 10:12 pm
Woke up to total fog cover, clouds and humidity. But, around 1pm Eastern, I was able to see through some sucker holes. Seeing wasn't very good, but it was good enough to attempt large scale. There's a new sunspot that looks like a small active region, but it's definitely a sunspot, a dipole, with two visible umbra that I resolved with a 150mm aperture. Some fairly large prominences are on the limb too. This sunspot is pretty interesting because it's such a high latitude on the solar disc in a region that sunspots of the 24th cycle really shouldn't be around. Maybe this is a sign of cycle 25?
Sunspot:
Proms:
Full Discs:
Earth Scale:
Setup:
Celestron 150mm F8 Refractor > Daystar 150mm ERF > Baader UV/IR Cut Filter > Quark Chromosphere > ASI174MM
PST > 1.5x Barlow > ASI174MM
Re: New Sunspot (Undesignated ATM), Big Proms, Full Disc | HA | Nov 9th 2018
Post by Carbon60 » Sat Nov 10, 2018 8:17 am
Another fine set of images, Marty. Looks promising for the start of the 25th, or maybe it’s wishful thinking :). We need some hope that things are starting to turn around.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by marktownley » Sun Nov 11, 2018 6:50 am
Super shots Marty! The spot is reversed polarity (compared to cycle 24 spots) so is part of cycle 25.
denababy
Post by denababy » Sun Nov 11, 2018 1:14 pm
As always fantastic.
Post by Montana » Mon Nov 12, 2018 10:19 am
A fantastic set Marty, what a lovely little spot :hamster:
