While it rained yesterday and I sat at work, I was content knowing I couldn't do anything anyways. Figured today would be the same so I went to work early. The sky was clear and no clouds, no rain, and it dropped into the 40's (F) which is really weird in Florida. So I went home early and managed to point the scopes at our minimum sun. I was pleasantly surprised with some rather large prominences (one really big group) and AR2728 was actively flaring with a lot of activity and I watched a filament curl around it over the course of minutes, so material was wiping around really fast. The seeing was pretty bad mid-day, I usually image much earlier in the morning.
B&W:
Colored:
Earth Scales:
AR2728 Flares & throwing Filaments Around:
(Forgive the really rough animation and bad transitions and differing exposures, I didn't plan on doing an animation, the seeing was pretty bad mid-day, but every time I went back and looked at AR2728 it changed, so quickly, the filament moved rapidly in a course of 30 minutes, so I sorted through a few videos and found enough different versions to show the changes over time.)
Equipment:
Celestron 150mm F8 Refractor
Daystar 150mm ERF
Daystar Quark Chromosphere
GSO 0.5x 2" Focal Reducer
PST + 1.5x Barlow
ASI174MM
Big Prom Group! AR2728 Flaring & Filaments, Full Disc | HA | Nov 27th 2018
- Has thanked: 1171 times
- Been thanked: 1360 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: Big Prom Group! AR2728 Flaring & Filaments, Full Disc | HA | Nov 27th 2018
You got some great images there Marty!
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
Very nice proms and animation. cheers
-Mike
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
I saw the flare on gong too. It looked strongest around 21:10 to 21:25 UT. Very nice capture Marty.
Christopher
- Been thanked: 4340 times
These are great images Marty
Nice to see whats going on...another cloudy day here
- Has thanked: 17666 times
- Been thanked: 8787 times
Wow!! never a dull moment then there are some cracking prominences and the tongue of material in the AR is very interesting
