Hi.
It was cloudy , but a good sized sucker hole tempted me to image the sun today. Sure enough, as soon as i had my gear fully setup, the hole was no more. I waited for another hole and was rewarded for my patience. Seeing, though, was not great at around 2/5. Transparency was at ~2/5 with high clouds. The first photo is a combination of a (subtle) high gamma surface image and a prominence image. The second image is when I'm too lazy (to take a surface image). I'd appreciate if you would let me know which looks better. thanks
equipment used: ASI120MM-S / TMB92 f5.5 / Quark
cheers,
Mike
Capture 14_23_13_g4_ap3724_Drizzle30 wav2 by Mike Enage, on Flickr
Capture 14_23_13_g4_ap3724_Drizzle30 wav by Mike Enage, on Flickr
Capture 14_38_20_g4_ap1398_Drizzle30 imppg4_5 bw by Mike Enage, on Flickr
Prominence & Surface - Nov 27, 2018
- Has thanked: 9145 times
- Been thanked: 6025 times
- Has thanked: 17672 times
- Been thanked: 8791 times
Re: Prominence & Surface - Nov 27, 2018
Wow! these are fantastic Mike, I like either version of the prominence, both have their plus points
Where abouts are you? nothing but torrential rain in the UK today.
- Has thanked: 20442 times
- Been thanked: 10247 times
Yes, great images indeed.
Thanks ! Franco
Thank you ! Alexandra . I'm in Manila
Thank you ! Mark
Thank you ! Mark
-Mike
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4787 times
Great image Mike … for me is the second the best.
Here in Belgium the whole week rain …
- Been thanked: 4340 times
The prom images are very good Mike, and each show the features slightly differently. They are close, but I prefer the pic with the chromosphere masked out as i find the bright disk competes with the prom too much.
