Woke up to some clouds, bummed, so just carried on with the morning. Noticed some light off my kitchen faucet so I peaked out and the clouds has moved on and I had a little window between more weather. I did some testing and gathered data on the brighter prominences and while scanning the chromosphere in high resolution I found a subtle active region that was interesting showing signs of a birthing plage and some filament generating activity swirling about so I grabbed data on that in case it becomes anything interesting later. No other major features currently.
B&W:
Colored:
Earth Scale:
Setup:
Celestron 150mm F8 Refractor
Daystar 150mm ERF
Daystar Quark Chromosphere
PST Etalon
ASI174MM + 0.5x Focal Reducer
Prominence, Active Region | HA | Jan 12th 2019
- Has thanked: 1171 times
- Been thanked: 1360 times
Re: Prominence, Active Region | HA | Jan 12th 2019
Marty,
Interesting looking prom. I like it! You had to look very hard to find something on the surface today.
Phil
Phil
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
- Has thanked: 9144 times
- Been thanked: 6025 times
Hey Marty: love that prominence and the spicules.
- Has thanked: 20424 times
- Been thanked: 10243 times
Good results Marty! You skies look nice and blue in between the clouds.
- Been thanked: 4340 times
Superb set of images from this session Marty...nicely done
- Has thanked: 17667 times
- Been thanked: 8787 times
Very nice shots, you are picking up the tiny details
