Solar Minimum Sunshine 9th February
- Has thanked: 20817 times
- Been thanked: 10487 times
Saturday morning was one of those race against time mornings. I woke far too early - Mrs Townley was not impressed, either way I enjoyed watching it get light with a mug of coffee. I could see on SAT24 that it was clear (then), but also cloud was coming fast. I set up with the SM90 and the PGR GH3 ICX814, and by then it was a case of pressing the stop start button in Firecapture to avoid the scudding clouds.
Ha-FD.composite-bw by Mark Townley, on Flickr
Ha-FD.composite-colour by Mark Townley, on Flickr
Nothing to see here, move along... Saturdays disk is fairly typical of a solar minimum sun - the disk looks blank. There is a small region of very decayed plage from active regions several rotations ago but that it is it on the surface. The proms were the star of the show, and looked fantastic through the SM90 with an 18mm Coronado Cemax eyepiece. This image is a composite disk / proms shot with the PGR GH3 ICX814 camera. Poor seeing and haze were the order of the morning to give imaging that extra challenge, but it is nice to see the sun rising higher and higher in the sky with each passing week. Wonder how long these conditions will last until we see the signs of cycle 25 becoming more predominant and obvious in the solar northern hemisphere?
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Re: Solar Minimum Sunshine 9th February
Mark,
The proms look great and you captured that decayed AR very nicely. Glad to see you’re getting a little sky time again.
Christopher
Thanks Christopher, if the weather is obliging i'm now able to get back into solar observing on a weekend if the skies are clear...
- Has thanked: 1640 times
- Been thanked: 878 times
- Has thanked: 1188 times
- Been thanked: 1382 times
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Good result Mark, good to see the Sun is high enough (just) for you to start imaging again.
David
Kit: Skywatcher Evostar 120 on Celestron CG-4 / Bresser AR102xs / Lunt B1200 Ca-K Module / Lacerta Herschel Wedge / Daystar Combo Quark / ZWO ASI178MM & 120MC-S / QHY5-II Mono
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Nice images there Mark, clearly a slow sun
Pedro Re'
- Has thanked: 9319 times
- Been thanked: 6157 times
Hi Mark: good results, the 814 camera seems to be working well with the SM90.
With that size pixels, can it also be used with the HaT, maybe with the 0.7 focal reducer ?
- Been thanked: 4980 times
Mark:
A very nice session, clean and sharp FD´s
It is very annoying to pause and start every time a cloud passes by.
- Been thanked: 8906 times
That's a great full disc Mark, fantastic proms I remember at the start of solar cycle 24 you were one of the first people to catch a massive prom on the Sun, wasn't it used on Spaceweather or NASA or something?
- Been thanked: 4427 times
Hi Mark...
Great capture with the proms making up for the slow disk activity
The new scope and camera certainly make a great pair!!!
Thanks all! Yes, I remember that prom Alexandra, although I was just looking through my website and there were quite a few big proms at the start of 24....
- Has thanked: 8558 times
- Been thanked: 8290 times
That’s a very nice disk, Mark.
Thanks Stu.
A closeup of the relic active region, SM90, 2.5x barlow and PGR Blackfly IMX249 camera.
ha-close-bw by Mark Townley, on Flickr
ha-close-colour by Mark Townley, on Flickr
Your SM90 rocks, Mark. Pretty amazing for a single stack.
Thanks Franco, I probably won't use it with the HaT even down at f22. 9fps is way too slow at that scale, it works for full disks but hi res needs a higher cadence.
