First attempt at an animation
- Has thanked: 128 times
- Been thanked: 121 times
Not the best, but you gotta start somewhere. It's good to know that I left room for improvement
This is from 4 May, over a 4 1/2 hour period
Lunt LST80Ha
TeleVue 5x Powermate
ZWO ASI174MM
I was using SharpCap for acquisition for this one, but the next time I'll give it a go with Genika Astro, which sets up sequences better and also includes SSM input. SharpCap allows quality-based acquisition but the algorithm, which apparently uses a simple contrast ratio, is fooled by clouds and some other conditions. Sometimes it works great, sometimes not as well. With Genika Astro, the acquisition is controlled by the flicker observed by the SSM and I'm hoping it will do better.
Lunt LST80Ha
ZWO ASI174MM
- robert
- Has thanked: 4 times
- Been thanked: 1287 times
Re: First attempt at an animation
Very nice animation. Long time too. (Firecapture is good for sequences and connects to ssm.)
Robert
Robert
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
This is a great first animation. I also use Firecapture with SSM and it works very well using the plug in developed by PDB (user on SolarChat).
Christopher
- Has thanked: 9387 times
- Been thanked: 6201 times
- banjo
- Has thanked: 2123 times
- Been thanked: 2903 times
Very good animation .
sorry for my English translators google
- Has thanked: 18105 times
- Been thanked: 8942 times
Wow! it is nice to see visible movement in the Sun turning too, it gives a very impressive grand scale
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
- Has thanked: 20962 times
- Been thanked: 10593 times
Looking good!
- MAURITS
- Has thanked: 2501 times
- Been thanked: 4928 times
Is the Genika Astro better then the "FireCapture" software?
I plan to buy the SSM monitor in the near feature and I don't know if I buy the Genika Astro software together.
- Has thanked: 1200 times
- Been thanked: 1390 times
The Genika Astro software was developed by the maker of the SSM, so I wanted to use that. I have tried Firecapture a couple of times and find the human interface to be clunky. I find SharpCap much easier to use. But Genika Astro is not a polished piece of software. Apologies to Frederic if he is here. While functional, the human interface appears to have evolved as various capabilities and features were added to the program. I made my living as a programmer and have been guilty of taking the same approach, so I know what it looks like. As you can see from my comments, I wasn't able to find a very important parameter while using the program despite the fact that I had found it before.
I have not attempted to use the SSM with Firecapture. Perhaps that should be the next thing for me to try
- Has thanked: 1 time
- Been thanked: 2725 times
This s quite a good start. On top of that the rotation on the solar sphere is visible.
What is the parameter you didn't find ?
- MAURITS
christian viladrich wrote: ↑Fri May 10, 2019 8:31 pm This s quite a good start. On top of that the rotation on the solar sphere is visible.
Christian -
I couldn't find the setting for the SSM trigger threshold. It's a slider under Options | Other
