AR2740 & 2741 in Ha with the C8 EdgeHD on May 10
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
This morning the large passing cumulus kept respectfully at a distance of the Sun for at least 2 hours. This was quite unexpected since the forecast said it was going to rain.
The current two sunspots are pretty small though the surrounding activity gave nice views.
Best regards
Has thanked: 9298 times
Been thanked: 6133 times
Re: AR2740 & 2741 in Ha with the C8 EdgeHD on May 10
Post by ffellah »
Super images, Christian. I see you are using the F/35 telecentric: how do you like it compared to the 27.5 ? To use that, the seeing must be exceptional ? Very fine processing for these two images..also using the SS RG
Astrophil
Been thanked: 581 times
Post by Astrophil »
Excellent images. Always great to see what aperture and experience can produce. Thanks.
Phil
Has thanked: 1 time
Thanks guys :-)
The F/35 gives a narrower effective bandpass. The effective bandpass of a 0.3 A filter is about 0.5A at F/27 and 0.4A at F/35 :
I have a test image comparing both F-ratio somewhere on my website.
Has thanked: 17925 times
Been thanked: 8894 times
Wow! I would give anything to have such nice photos as these :bow :bow :hamster:
Christopher
Has thanked: 33 times
Been thanked: 34 times
Post by Christopher »
Exquisite detail Christian.
Christopher
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
Excellent images Christian.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 20757 times
Been thanked: 10442 times
Very nice shots indeed Christian!
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Outstanding image Christian...well done :bow
