Fridays Calcium Images - 5th July
Has thanked: 1289 times
Been thanked: 536 times
Post by marktownley » Sun Jul 07, 2019 8:55 am
The sky was beautifully transparent on friday morning, deep blue and lacking in any haze, so I decided to have a go at some calcium imaging, and at the same time test out the Grasshopper 3 IMX174 at these shorter wavelengths for some closer images. First up though the full disk, prime focus with the 100mm Tal refractor at 1000mm focal length, using the homebrew CaK filter and the GH3 ICX916M camera, make sure you double click for the full size view in flickr.
ImageCak-FD-bw by Mark Townley, on Flickr
ImageCak-FD-colour by Mark Townley, on Flickr
You can just about make out the inverse granulation that is visible. Granulation is a feature of the photosphere we can see in white light, where cells of solar plasma rise and fall. The edges of the cells are cooler with the falling plasma and so the boundaries appear darker - regular granulation. With inverse granulation we are viewing the same features at the base of the chromosphere, here the cells themselves are a lot cooler than their edges, so, the cells are darker and the cell edges / boundaries appear lighter. It's all about 'relative' light levels in the same way that sunspots appear dark on the solar disk, despite them being only slightly 'cooler' than the surroundings they sit in.
Anyways, zooming in with the same scope and 3x barlow with the GH3 IMX174 camera this time with its larger pixels I set out to explore the sun. First off the region of plage that is associated with the active regions that first appeared at the end of march / beginning of April.
Imageex-ar-cak-bw by Mark Townley, on Flickr
Imageex-ar-cak-colour by Mark Townley, on Flickr
I wonder in another couple of weeks time there will still be some plage remaining, albeit at diminished extent? A small emerging flux region was also visible in (cycle 24) equatorial regions, that may well have just sported a few pores briefly.
Imageefr.-bw by Mark Townley, on Flickr
Imageefr.-colour by Mark Townley, on Flickr
Turning my attention to the poles, and polar faculae indicative of solar minimum were visible in both hemispheres:
Imagenpole-cak-bw by Mark Townley, on Flickr
Imagenpole-cak-colour by Mark Townley, on Flickr
Imagepolar-cak-bw by Mark Townley, on Flickr
Imagepolar-cak-colour by Mark Townley, on Flickr
First impressions are I like this camera at CaK wavelengths, probably more so than at Ha, the fast frame rate certainly helps. I think next steps will be to try it out with the SSM to get better data to play with. All these were stacks of only 16 images. Did get some Ha too, but will have to wait till later to process them.
pedro
Has thanked: 2 times
Been thanked: 325 times
Re: Fridays Calcium Images - 5th July
Post by pedro » Sun Jul 07, 2019 11:59 am
Beautiful CaK images Marke, great definition. The IMX174 works well in CaK
Has thanked: 5 times
Been thanked: 119 times
Post by MapleRidge » Sun Jul 07, 2019 12:25 pm
Hi Mark...
Superb CaK images for this data set...excellent work :bow
Also great explanation of the difference in the granulation between the two filters...thanks!
Post by marktownley » Sun Jul 07, 2019 4:28 pm
Thanks Pedro, thanks Brian! :)
MAURITS
Been thanked: 14 times
Post by MAURITS » Sun Jul 07, 2019 5:50 pm
Great results Mark.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
krakatoa1883
Has thanked: 39 times
Been thanked: 111 times
Post by krakatoa1883 » Sun Jul 07, 2019 7:22 pm
Great images, and explanations, Mark. Is the full disc a mosaic ?
Post by marktownley » Sun Jul 07, 2019 7:36 pm
Thanks Maurits, thanks Raf. The full disk is one image, not a mosaic Raf.
Has thanked: 1124 times
Been thanked: 381 times
Post by Montana » Mon Jul 08, 2019 11:12 am
Another excellent and informative post Mark :bow2
Superb set of Calciums too :bow :bow
Yes it was a gorgeous day on Friday, I had high hopes for Saturday and it poured with rain all morning until around 2pm, then had to trim the hedge as the neighbour was anxiously waiting to turf his lawn. I think we were the only place in the UK to get this band of rain, typical.
Has thanked: 465 times
Been thanked: 364 times
Post by Carbon60 » Tue Jul 09, 2019 5:31 am
Excellent post, Mark. Informative and with beautiful images.
I was in Redditch on Friday and experienced the same conditions that you did. Unfortunately I didn’t have any solar kit with me. Picnicked with family in the Park instead.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by marktownley » Tue Jul 09, 2019 6:06 am
Thanks Alexandra, thanks Stu.
Here is the Ha from the same day. I think the CaK is my preference from the session. FD with the SM90 and GH3 ICX916M, closeup same scope with the 3x barlow and GH3 IMX174...
Imageha-fd-bw by Mark Townley, on Flickr
Imageha-fd-colour by Mark Townley, on Flickr
Imageex-ar-ha-bw by Mark Townley, on Flickr
Imageex-ar-ha-colour by Mark Townley, on Flickr
Looks like cloud for the week for me now!
Martin_S
Has thanked: 31 times
Been thanked: 136 times
Post by Martin_S » Tue Jul 09, 2019 7:40 am
Great pictures Mark . Do you have a link to your homebrew CaK filter? the results are amazing.
Martin
H - alpha setup
White Light setup
Skywatcher ED72 ,ED100, Homemade solar wedge, IR cut filter, Solar Continuum filter.
Mounts
Skywatcher HEQ5 Pro Mount ..
Darkside setup
Skywatcher ED72 ,ED100, GSO RC6 ,Celestron Nexstar 6SE.
MAURITS
Post by MAURITS » Tue Jul 09, 2019 1:16 pm
Excellent, with some nice details Mark.
Maurits
Post by MapleRidge » Sun Jul 14, 2019 1:25 am
Superb addition of Ha images Mark...excellent work :bow
banjo
Has thanked: 7 times
Been thanked: 127 times
Post by banjo » Mon Jul 15, 2019 5:55 am
Great Picture , :bow :bow :bow :bow :bow
