Quark f52 first attempt 9/21
- Has thanked: 141 times
- Been thanked: 240 times
I am experimenting with masking my 152mm to 95mm and like the results in many cases. This morning I tried masked and unmasked with a 2x barlow bringing the image below to about f52 for the 152mm and f84 for the 95mm (masked). On my monitor I was thrilled every time the clarity "popped" into crispness...even at f84 when masked at 95mm I had a blast watching the sun very up close.
In post processing I had better results with the 152mm unmasked (f52).
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
Re: Quark f52 first attempt 9/21
And here is one from 9/20 with the 95mm mask and no Barlow so about f42.
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
- yltansg
- Has thanked: 1460 times
- Been thanked: 1447 times
- Has thanked: 17960 times
- Been thanked: 17110 times
Very nice!!
- Has thanked: 9387 times
- Been thanked: 6201 times
- MAURITS
- Has thanked: 2501 times
- Been thanked: 4928 times
- Has thanked: 65 times
- Been thanked: 4462 times
Looks good Jack!!!
Thanks everyone! Having fun.
Keep the coaching coming.
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
- Been thanked: 5016 times
- Has thanked: 20962 times
- Been thanked: 10593 times
Nice shots! You're brave going to those crazy focal ratios!
- Has thanked: 18105 times
- Been thanked: 8942 times
Wow!! always good fun to see the details pop on the screen
- Has thanked: 8596 times
- Been thanked: 8325 times
Nice images, Jack. It’s always a balancing act between aperture, focal ratio, pixel size and seeing to obtain optimal results.
