The sun is very bland today. I can see only one tiny prominence and maybe one tiny filament near the limit of visibility. Otherwise only the ever-present solar filagree is seen. White light is even more featureless. Not a spot in sight. I hope you guys do better with imaging!
2-13-20 observations
- Has thanked: 17832 times
- Been thanked: 16976 times
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: 2-13-20 observations
Blankety blank!
Seriously blank! It's funny. I chose solar minimum to dive into solar astronomy.
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Don't worry about it being solar minimum - when things pick up you will have honed your solar skills & then pow!
- Has thanked: 17970 times
- Been thanked: 8904 times
Well you saw more than GONG then I guess the small prom was the one in the south east, where was the tiny filament?
Starting viewing in solar minimum is a good thing, I started in the last solar minimum and I got really excited by the smallest detail. If you start at maximum then you are spoiled
Alexandra,
The filament was located near disc center. It shows up as a tiny darker area just left of the disc center on the GONG Ha image. I am not even sure it is a filament. Maybe only a cluster of unresolved spicules in the chromospheric filagree.
I hope starting during minimum does help me hone my skills.
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- Been thanked: 4971 times
Certainly blank. I eagerly await sunspots!
