Spot, Granulation, Facula, Pattern in KLine with a T300
- Has thanked: 714 times
- Been thanked: 496 times
Hi!
Here a first set of pics taken from St Véran (French Alps) with a non aluminized 12" mirror.
The pics are taken in KLine (296nm).
CS
Alex
2020-08-9 & 14
Solar newton T300 F1800
FFC
KLine
ASI174
CS
Alex
2020-08-9 & 14
FFC
KLine
ASI174
- Has thanked: 9145 times
- Been thanked: 6026 times
- solardave
- Has thanked: 10 times
- Been thanked: 219 times
Re: Spot, Granulation, Facula, Pattern in KLine with a T300
fantastic job
tak 102fs solarmax40 ds es ed80 cornado 90mm filter bf10 bf 30 skynyx 2-2 mono camera lunt 2inch wl wedge lunt b1800 cak mod
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Fantastic resolution Alex
Pedro Re'
- Has thanked: 17581 times
- Been thanked: 16697 times
Alex,
I thought at first these were taken in Continuum until I read your post. The supergranules of the lower chromosphere look a lot like the granules of the photosphere but are a bit larger. Your resolution is excellent here! Very nice images!!
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
Excellent work, Alex.
I also thought I was looking at the photosphere in that first image until I noticed the finer detail. Absolutely stunning capture!
- Has thanked: 17672 times
- Been thanked: 8793 times
Absolutely incredible imaging I presume this is the Photosphere granulation with faculae visible around the spot. Is this the Baader K line filter? as this only shows the photosphere with enhanced faculae, however, you confuse me with 296nm?
- krakatoa1883
- Has thanked: 153 times
Fantastic granulation detail
- sulcis2000
- Has thanked: 2 times
- Been thanked: 477 times
TOP!
Alessandro Bianconi
________________
Celestron C14HD Edge
Celestron C14XLT made in USA
Refractor 228 F8 Truss Tube with D-ERF 110mm
Sharpstar 76PHED
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar V4
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
Basler Aca1920-155um
ZWO ASI462MC
Celestron Skyris618M
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
- grimble_cornet
- Been thanked: 47 times
Amazing resolution!
Mike Garbett
Mike Garbett
- Been thanked: 4904 times
- Has thanked: 1262 times
- Been thanked: 1057 times
Incredible images! All together, setup, high altitude and the author of course, gives a fantastic result!
regards
Leo
regards
Leo
Thank you again for the comments.
Leo, you would wonder my setup: the mirror is an old mirror from the 80's which has been converted to solar, the truss and other parts are second hand, which I adapted a bit in my garage.
The old F6 optic looks to be good and I have a good secondary also.
I should give a try with this setup in my area.
CS
Alex
CS
Alex
