G band instead of Ca-k filter
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, would anyone know if this filter would work for G-Band imaging/observations. From Edmand Scientific 430nm CWL, 25mm Dia., Hard Coated OD 4.0 10nm Bandpass Filter. Obviously I'd use a pre filter probably baader solar film. Possibly on either my C11 f10 or 80ED f7. Appreciate any input.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: G band instead of Ca-k filter
Yes it would work, you might find you need a UV/IR filter with it too. I'd cut your teeth with the 80mm first rather than the c11.
- Stardust5858
Thanks Mark, appreciate your input. Not seen much about people going down this road but read a post on here. It's interesting as the cost isn't prohibited at around £177.marktownley wrote: ↑Mon Nov 23, 2020 10:29 pm Yes it would work, you might find you need a UV/IR filter with it too. I'd cut your teeth with the 80mm first rather than the c11.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Bob Yoesle
- Has thanked: 541 times
- Been thanked: 811 times
An f10 achromatic refractor is your best bet for significantly better spherochromatic aberration at 430 nm:
https://www.telescope-optics.net/achromats.htm
A shorter f ratio APO or semi-APO (except Tak TAO 130/150 ;-) will generally not perform as well:
https://www.telescope-optics.net/semiap ... amples.htm
A SCT will be pretty poor at 430 nm, but with a suitable corrector lens, may be capable of much better results:
http://www.astrosurf.com/viladrich/astr ... C8Edge.htm
http://articles.adsabs.harvard.edu/cgi- ... etype=.pdf
- Has thanked: 17839 times
- Been thanked: 16976 times
Bob,
I always wondered what wavelength G band was. So it's 430 nm? That's in the blue-violet region of the spectrum. That would be quite a bit easier to see visually than CaH or CaK would be. What features would that concentrate on? PhotoSphere-Chromosphere transition region?
And I have an F10 achromatic refractor!
- Has thanked: 8543 times
- Been thanked: 8278 times
I occasionally use the same filter on the output side of my Lacerta wedge with the brightness toned down with a suitably rotated polarising filter. I also have a UV/IR filter attached to the input side of the wedge for additional protection.
The ‘G-band’ at 10nm FWHM is not particularly tight, but it seems to enhance the granulation and faculae with a little more contrast than does my 540nm filter. I haven’t given it a full test drive in high res yet to see if it shows up any so called bright lanes between granules, so this is something to try in the spring with better conditions. A 2nm version may be better, if you can find one, but this filter works okay, as I say, for WL images with slightly improved contrast, but then that can also be achieved with processing.
- Stardust5858
Thanks StuCarbon60 wrote: ↑Tue Nov 24, 2020 8:06 am Hi,
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Another thought, would stacking up with a double stack430nm CWL, 25mm Dia., Hard Coated OD 4.0 10nm result in a narrower band of 5nm or am I being really stupid.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Simple answer, no!Stardust5858 wrote: ↑Tue Nov 24, 2020 3:50 pm Another thought, would stacking up with a double stack420nm CWL, 25mm Dia., Hard Coated OD 4.0 10nm result in a narrower band of 5nm or am I being really stupid.
G-Band imaging to be 'true' G-band needs to be considerably narrower, like Ha or CaK - ultra narrowband. The 430nm filter is effectively only a narrow band filter, where it benefits is the shorter wavelength gives increased resolution over 540nm.
- rsfoto
- Has thanked: 9710 times
- Been thanked: 5769 times
Hi Mark,marktownley wrote: ↑Tue Nov 24, 2020 3:58 pmSimple answer, no!Stardust5858 wrote: ↑Tue Nov 24, 2020 3:50 pm Another thought, would stacking up with a double stack420nm CWL, 25mm Dia., Hard Coated OD 4.0 10nm result in a narrower band of 5nm or am I being really stupid.
Resolution or Contrast ?... where it benefits is the shorter wavelength gives increased resolution ...
Hi Mark,rsfoto wrote: ↑Tue Nov 24, 2020 4:37 pmSimple answer, no!
[/quote]
Hi Rainer.
Resolution certainly yes, if the seeing allows then for a given aperture a the shorter wavelength gives higher resolution compared to continuum - 1.25x in fact. So, using a 430nm filter on a 100mm scope would give the same resolution as using a 540nm filter on a 125mm scope.
In terms of contrast I have no first hand experience, however I do fancy trying to image at these shorter wavelengths. The other thing to think about is it is very likely the telescopes strehl ratio will be lower at 430nm than 540nm - most scopes are best corrected for the green where our eyes are most sensitive. This will impact i'm sure.
'True' G-band is centred on 430nm +/-1nm, so, a 10nm filter really isn't narrow enough by far and is only giving a 'blue' white light view really.
As this solar cycle picks up a bit, it is something I will likely explore more.
Here's a good paper on G-Band http://articles.adsabs.harvard.edu//ful ... 3.000.html
- rsfoto
Hi Rainer.marktownley wrote: ↑Tue Nov 24, 2020 4:50 pmHi Mark,rsfoto wrote: ↑Tue Nov 24, 2020 4:37 pmSimple answer, no!
[/quote]
So by just putting a 430 nm filter instead of 540 nm filter I resolve more details ? For me resolution is for example 1" arc second per pixel or 0.5" arc second per pixel and 0.5" arc second per pixel is more resolution then 1.0" ...
How does that work if I use the same scope, the same camera that I get finer details = more resolution ?
Sorry but still very confused ...
- Stardust5858
Still interesting enough to put on the Santa list, lol. Thanks Mark.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Bob Yoesle
Resolution is wavelength dependent. So a shorter wavelength with the same aperture has the potential to have higher resolution if the optics and seeing conditions allow. For imaging of course you would need to match pixel size to the higher resolution to realize the benefit.
For example, the difference between H alpha and CaK is 656/394 nm = 1.66. Therefore imaging CaK with the same telescope will have 1.66 times the resolution of the H alpha. Equivalently you would need a 166 mm aperture telescope for H alpha to obtain the same resolution of CaK with 100 mm of aperture.
- Has thanked: 1188 times
- Been thanked: 1382 times
I have that filter (the E.O. 430nm 10nm OD4). Unfortunately it's not narrow enough to show Gband features. Andover used to have the filter that was narrow enough to be close to showing Gband features (it's $211, 2nm bandpass, but still basically too wide to show the Gband features, but it's never in stock for years now).
Also, the unique feature of Gband is very tiny and requires extraordinary seeing conditions and a very large aperture at critical sampling to achieve, the iron bits between convection cells, bright spots basically, are what are unique to the 430nm wavelength in the photosphere. It takes about a 10" aperture at critical sampling and it takes way more narrow bandpass, more like 1A~2A to even begin to to see the bright spots. So if you're not using a very narrow filter like that, and you're not resolving with a huge aperture, you're really not going to see anything special in 430nm photosphere imaging that you wouldn't already see with 540nm continuum or any other wavelength of photosphere. That means you need sub-arc-second seeing conditions (so basically go to a mountain top or an island with no jetstream, etc, you have to go to unique places on Earth to get that kind of seeing routinely and steady for this purpose).
The only benefit outside of that is that it's 430nm and thus higher angular resolution, so you could critically sample it and do higher resolution than 540nm continuum or similar common wavelengths. But if you're just going for angular resolution, then 430nm isn't what I would get, instead, look to a 395nm near UV (conintuum A) filter that is as narrow as possible, but be prepared to only use long focal-ratio refractors or newtonians (avoid SCT/Mak with fast mirrors, huge SA in these short wavelengths, not worth it).
So I use the E.O. 430nm filter basically for its angular resolution, with a long achromatic doublet refractor and a longer focal-ratio newtonian mirror (F6 or longer, Quartz) because these short wavelengths are not friendly with other optics that are fast focal-ratio and not figured for near UV and short wavelength like Calcium, Continuum A and Gband (ie, don't' use an SCT/Mak; the SA is too much and its useless basically, compared to just using a long focal-ratio refractor and/or newtonian mirror).
I use the Baader Blue CCD-IR block filter (2") as my sub-aperture D-ERF for 430nm when I'm using a refractor, no need for any special front mounted D-ERF for this. I then use a Baader 10 stop ND filter to cut transmission as the transmission is saturating even at 0.03ms exposure time with this. The 10 stop makes it reasonable and still very short (less than 1ms). Then the E.O. 430nm filter. I use a 290MM for this, for 2.9um pixels; 430nm critically samples at F16 on 2.9um pixels. For my 200mm F6 newtonian, I just use Baader Photo Grade Solar Film and the same 10 stop ND filter and the E.O. 430nm filter for the same effect, but it needs the film filter since its a mirror design.
Anyhow, here's results with this E.O. filter, under moderately high resolution with sub-arc-second seeing conditions. But 10nm bandpass simply won't show the unique Gbrand bright spots between the convection cells, and not at 8" aperture either. You'd need bigger aperture, better seeing, and a more narrow bandpass filter.
200mm F6 Quartz Newt with ND3.8 Baader Solar Film & E.O. 430nm 10nm Filter:
And here's from a 150mm F8 achromatic doublet with the Baader Blue CCD-IR Block filter as an internal D-ERF with the E.O. 430nm filter:
My advice: don't buy this filter for Gband. If you want higher angular resolution, get 395nm and really good seeing and use a big refractor or long focal-ratio newtonian. Otherwise, stick to 540nm or longer wavelength on any instrument type.
- Stardust5858
Many thanks for this, very informative. Will have to have a rethink.MalVeauX wrote: ↑Wed Nov 25, 2020 12:17 am Heya,
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
What kind of seeing conditions are you commonly seeing? Not your best ever. But your more likely seeing conditions? Short wavelength is very much effected by atmospheric seeing, unlike long wavelength which is less effected so it appears more steady at the loss of angular resolution. The increase in contrast using 430nm or any other shorter wavelength is relative to its resolution, higher resolution (if sampled appropriately and not limited by seeing), less blur, more contrast on transitions. But you have to have sub-arc-second seeing for this with a large aperture (even 6 inches is pushing it with 393~430nm near UV and into blue wavelengths). To attempt it with a C11, you'd have to follow Christian up into a mountain top to get that good 0.3" seeing to attempt 430nm or 395nm at critical sampling with an aperture like that.Stardust5858 wrote: ↑Wed Nov 25, 2020 11:39 am Many thanks for this, very informative. Will have to have a rethink.
If you've already exhausted and tapped out red and near IR wavelengths with your C11 for photosphere imaging, then by all means, go where you're next challenge is. But if you've not gotten some critically sampled red/IR wavelength convection cell/spot images with your C11, then start there first. You still need sub-arc-second seeing but your odds of lucky imaging are significantly higher than attempting it with 395~430nm.
Here's an example of the kind of seeing I need to even begin to attempt 430nm or 393nm with 6" or 8" apertures, critically sampled. This isn't my every day seeing, my every day seeing is around 1" in the mornings give/take a bit. In the spring and summer it's sub-arc in the morning, but in the late fall and into winter, it goes up into the 1.5~2" fast. But I can reliably image sub-arc second in the late spring and summer when its warm with the least amount of temp swing from night to morning. This is the reason I can attempt 8" aperture solar at critical sampling.
- Stardust5858
Thanks Martin. My seeing can be very variable living by the seaside. Also the jet stream can be turbulent over the South West of the UK. However in saying that I've had very good seeing usually early morning in spring and autumn. I'll probably go down the Lunt Cak route instead for now to compliment the HA I'm currently doing.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Sounds goodStardust5858 wrote: ↑Wed Nov 25, 2020 4:20 pm Thanks Martin. My seeing can be very variable living by the seaside. Also the jet stream can be turbulent over the South West of the UK. However in saying that I've had very good seeing usually early morning in spring and autumn. I'll probably go down the Lunt Cak route instead for now to compliment the HA I'm currently doing.
Honestly, while there are some less popular options like Gband, SodiumD, etc, ultimately the top ones for showing the major features really comes down to CaK, HA and any form of photosphere continuum (be it 540nm or even just red 656nm, whatever has the best seeing conditions to sample). This shows the upper chromosphere, lower chromosphere and photosphere. Pretty much the best trio to focus on.
If you're super interested in many wavelengths, and you're ok losing resolution, look into building a digital spectroheliograph and image any wavelength that fancies you. I'm wanting to build one of these just for fun to explore the less popular frequencies.
- Stardust5858
Thanks, appreciate your help and advice.MalVeauX wrote: ↑Wed Nov 25, 2020 5:21 pmSounds goodStardust5858 wrote: ↑Wed Nov 25, 2020 4:20 pm Thanks Martin. My seeing can be very variable living by the seaside. Also the jet stream can be turbulent over the South West of the UK. However in saying that I've had very good seeing usually early morning in spring and autumn. I'll probably go down the Lunt Cak route instead for now to compliment the HA I'm currently doing.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Where would I find a 430nm filter and would it be of any real use visually? Would it benefit me in a similar way as a 540nm filter does? Obviously a true ultra-narrowband Gband filter would be better but I bet they are pricier too.
- Stardust5858
I found this one at:-DeepSolar64 wrote: ↑Thu Nov 26, 2020 3:29 am Where would I find a 430nm filter and would it be of any real use visually? Would it benefit me in a similar way as a 540nm filter does? Obviously a true ultra-narrowband Gband filter would be better but I bet they are pricier too.
Edmund Scientific.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Do they make a 1.25" size? One that will screw into an eyepiece?Stardust5858 wrote: ↑Thu Nov 26, 2020 2:52 pmI found this one at:-DeepSolar64 wrote: ↑Thu Nov 26, 2020 3:29 am Where would I find a 430nm filter and would it be of any real use visually? Would it benefit me in a similar way as a 540nm filter does? Obviously a true ultra-narrowband Gband filter would be better but I bet they are pricier too.
Edmund Scientific.
No, these are filters for laser system optics, their sizes are not natively designed to go in 'scope sizes', however they will fit with a suitable sized cell to hold them.DeepSolar64 wrote: ↑Thu Nov 26, 2020 4:03 pmDo they make a 1.25" size? One that will screw into an eyepiece?Stardust5858 wrote: ↑Thu Nov 26, 2020 2:52 pmI found this one at:-DeepSolar64 wrote: ↑Thu Nov 26, 2020 3:29 am Where would I find a 430nm filter and would it be of any real use visually? Would it benefit me in a similar way as a 540nm filter does? Obviously a true ultra-narrowband Gband filter would be better but I bet they are pricier too.
Edmund Scientific.
Does anyone make one to mount in an eyepiece, already mounted in a 1.25" cell? I am surprised Baader does not have one.
Nope, just us nerds on here aware of them.DeepSolar64 wrote: ↑Thu Nov 26, 2020 4:27 pm Does anyone make one to mount in an eyepiece, already mounted in a 1.25" cell? I am surprised Baader does not have one.
I have that filter, I mounted it into a 28mm holding cell (standard 1.25") which then threads to anything like a typical 1.25" filter.DeepSolar64 wrote: ↑Thu Nov 26, 2020 4:03 pmDo they make a 1.25" size? One that will screw into an eyepiece?Stardust5858 wrote: ↑Thu Nov 26, 2020 2:52 pmI found this one at:-DeepSolar64 wrote: ↑Thu Nov 26, 2020 3:29 am Where would I find a 430nm filter and would it be of any real use visually? Would it benefit me in a similar way as a 540nm filter does? Obviously a true ultra-narrowband Gband filter would be better but I bet they are pricier too.
Edmund Scientific.
That said, this is not a useful filter for visual, and frankly not that useful for imaging either. See above notes.
Stick to 540nm, or longer, for photosphere visual. Going any shorter wavelength, visually to see something meaningfully different than just the photosphere would be 396nm and even then only at around 5~6A or less. CaH basically. Shorter than that and you likely won't see anything due to yellowing of your cornea.
Thanks Marty,
I do already have a 540nm filter. I would like to have one of those Sodium Quarks to use with my Astro-Tech AT72EDII refractor.
marktownley wrote: ↑Thu Nov 26, 2020 4:32 pmNope, just us nerds on here aware of them.DeepSolar64 wrote: ↑Thu Nov 26, 2020 4:27 pm Does anyone make one to mount in an eyepiece, already mounted in a 1.25" cell? I am surprised Baader does not have one.
- Has thanked: 1 time
- Been thanked: 2725 times
Here is a comparison of a G-band 430-10 nm filter (Edmund Optics) and a 430-2nm filter (Andover Optics). The 2 nm FWHM filter provides more contrast on intergranular bright points.
The intergranular bright points (also called G-band bright spots) are also visible with a 395-5 nm filter or with Baader K-line filter :
The minimum diameter required to observe the G-band bright spots is 200 mm (in best condition and only for the larger points) but this is definitely better with a 300 mm telescope (and excellent seeing).
The G-band filter is also my favourite for visual observation of granulation and sunspot with my Taka TOA 150. The contrast and resolution is increased compared to a continuum green filter.
You have to check Andover "surplus" for the 430-2 nm or a 396-5 nm filter.
- Stardust5858
Would this be a good filter. 433.9nm 1.0nm 25mm
Andover Custom BP filter CWL 433.9nm/HBW 1.0nm/25.0mm dia.
433.9 / 1.0 - 59622
$154.05
Center Wavelength 433.9+0.2/-0 nm
Bandwidth 1.0+0.2/-0.2 nm
Transmission 40%
Blocking 1x10-4 avg. X-Ray to FIR
Size +0/-0.25mm
Thickness 7.0 +0/-nom mm
Effective refractive index (n*) -
Filter Type 2 (Click for profile)
CSV File (typical) N/A
433.9 / 1.0 - 59622
$154.05
Transmission 40%
Size +0/-0.25mm
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Unfortunately not. It should be 430.5 nm. The 433.9-1 nm is off G-band.
This is the right filter :
Custom BP filter CWL 430.7nm/HBW 2.0nm/25.0mm
https://www.andovercorp.com/products/su ... s-filters/
- Stardust5858
Thanks for your helpchristian viladrich wrote: ↑Sat Nov 28, 2020 10:13 pm Unfortunately not. It should be 430.5 nm. The 433.9-1 nm is off G-band.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Sorry for being a pain. Would this work, can't find an exact 430nm.
Andover Center Wavelength 430.7+0.4/-0.0 nm
Bandwidth 2.0+0.5/-0.5 nm
Transmission 45%
Size +0/-0.25mm
Thickness 9.5 +0/-nom mm
Transmission 45%
Size +0/-0.25mm
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Have you tried plumbing in the shipping costs to the UK from Andover? They are likely to be more than you think. There's customs excise and everything on top too...
From what I can see they don't have stock for that filter.
Have you imaged at 540nm with a continuum filter?
- Stardust5858
Yeah, I've thought about all the added cost too. I've a Lunt so only done ha. I'll probably add a Lunt Ca K next year, seems like the best way to go plus WL. Seems most seem to do these tri band observations. I've a white light filter for my birthday next week for my C11 and 80ed.marktownley wrote: ↑Sun Nov 29, 2020 11:01 am Have you tried plumbing in the shipping costs to the UK from Andover? They are likely to be more than you think. There's customs excise and everything on top too...
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Keep in mind what Christian pointed out, you need a big aperture and his seeing was sustained 0.7~0.8 arc-seconds, and as good as 0.3 arc-seconds. This isn't anyone's backyard seeing. This was at a specific location with exceptional seeing conditions. Professional observatory location class. G-band is really a fickle unicorn for most, simply due to the seeing requirements of such a short wavelength. For the same reason few people are able to image high resolution Calcium K (393nm) with enormous apertures.
100% agree with you here Marty.MalVeauX wrote: ↑Tue Dec 01, 2020 7:51 pm Keep in mind what Christian pointed out, you need a big aperture and his seeing was sustained 0.7~0.8 arc-seconds, and as good as 0.3 arc-seconds. This isn't anyone's backyard seeing. This was at a specific location with exceptional seeing conditions. Professional observatory location class. G-band is really a fickle unicorn for most, simply due to the seeing requirements of such a short wavelength. For the same reason few people are able to image high resolution Calcium K (393nm) with enormous apertures.
Sage advice!
Sorry, I was not arround.Stardust5858 wrote: ↑Sun Nov 29, 2020 9:28 am Sorry for being a pain. Would this work, can't find an exact 430nm.
Transmission 45%
Size +0/-0.25mm
Yes, this is the one. Two pieces were still available a few days ago, but now none ...
This is completely true.MalVeauX wrote: ↑Tue Dec 01, 2020 7:51 pm Keep in mind what Christian pointed out, you need a big aperture and his seeing was sustained 0.7~0.8 arc-seconds, and as good as 0.3 arc-seconds. This isn't anyone's backyard seeing. This was at a specific location with exceptional seeing conditions. Professional observatory location class. G-band is really a fickle unicorn for most, simply due to the seeing requirements of such a short wavelength. For the same reason few people are able to image high resolution Calcium K (393nm) with enormous apertures.
Just because it was asked, you can get filter mounts with threaded cells that will hold a 25mm filter.
https://www.ebay.com/itm/Eyepiece-Filte ... 236afeeb55
If you search eyepiece filter mount 28mm for 25mm filter you'll find lots of these out there.
I bought this exact one and it held my EO 430nm no problem.
But I still don't recommend the 430nm filter.
MalVeauX wrote: ↑Wed Dec 02, 2020 6:09 pm Heya,
So you recommend the 540Nm filter?
Yes, it's a good filter, it's as short wavelength (high angular resolution) as I would go, visually, unless you have exquisite seeing conditions. Even then, it's not needed, a polarized filter and something like a red filter will often be more useful simply because seeing will generally always be poor, and red will steady the seeing more than green will.DeepSolar64 wrote: ↑Thu Dec 03, 2020 5:53 amMalVeauX wrote: ↑Wed Dec 02, 2020 6:09 pm Heya,
I hope in time to get a Sodium D line Quark for my AT72EDII refractor. With 72mm of aperture it shouldn't require an ERF but only a UV/IR cut filter.
http://www.daystarfilters.com/Quark/NaQuark.shtml
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
I have one purchased from the Andover dealer in Italy. It works fine, very sharp and contrasty. It requires plenty of light so I put it just behind the Baader wedge (on 100mm ED refractor) with no neutral filters inside. For using this filter seeing needs to be really good.Stardust5858 wrote: ↑Sun Nov 29, 2020 9:28 am Sorry for being a pain. Would this work, can't find an exact 430nm.
Transmission 45%
Size +0/-0.25mm
And this is the key takeaway from this thread!
I might go for Gband if I had consistently better seeing. I don't, especially this time of year
