Hydrogen-alpha FD 16th Feb 2021
- Has thanked: 8559 times
- Been thanked: 8297 times
Another one of those frustrating sessions with mostly cloud cover and only small, elusive gaps, but I really wanted to try my new Coronado BF15 on my DS Lunt 60. It took almost an hour of patient waiting and a few aborted attempts before I managed to capture four panes to build up the mosaic
Basler acA1920-155um (IMX 174)
2.5x Powermate
Genika Astro
AS!3
ImPPG
MS ICE
PixInsight
Given the conditions and the rush to image in the gaps (no real time to finesse the tuning) I was really quite pleased with the final result and performance of the new BF. Overall, very promising for when there's a better weather day.
Processed in mono and colour
20210216_Ha_FD_mono by Stuart Green, on Flickr
20210216_Ha_FD_colour by Stuart Green, on Flickr
It's now raining...
Thanks for looking.
2.5x Powermate
Genika Astro
AS!3
ImPPG
MS ICE
PixInsight
It's now raining...
Thanks for looking.
- Has thanked: 20828 times
- Been thanked: 10502 times
Re: Hydrogen-alpha FD 16th Feb 2021
That came out really well Stu! That BF15 seems to do the job nicely.
Thanks, Mark.
I would never have managed to capture such images under these conditions with the Lunt BF.
It's surprising the difference these small changes can make. I've been dodging rain all day myself, looks like it's going to be the theme for the rest of the week.
- Has thanked: 17860 times
- Been thanked: 17005 times
Very nice Stu! I was able to get a few of those filaments today visually.
- Been thanked: 4900 times
Well done Stu, for a quiet Sun, you certainly showed the filaments very well.
Cheers
Cheers
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely Stu, well done and thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4434 times
Nice sharp image Stu...well done
- Has thanked: 9327 times
- Been thanked: 6163 times
Very nice images, Stu. Not much to do here between rain, snow, cold, etc.
Many thanks, everyone.
I can’t wait for better weather and a more active Sun.
- Been thanked: 8907 times
I swear there is much more contrast on this disc shot than normal, a good side by side test would be very interesting. Nice work
Hi Alexandra,
Absolutely. This was the main finding. These are not composite images as the disk and proms were captured at the same time. Usually I have to knock down the gamma setting to bring out the proms, but at the cost of losing contrast on the disk. Here I used the default setting (1 on Genika Astro), which happily showed the proms and disk features quite well.
When eventually we get another sunny morning, I'll be able to refine the tuning and hone the settings to obtain an optimal image. Can't wait.
Some more solar activity would be nice too.
Pouring down again here this morning
